Discuss
How to remove timer and replace
 in
Washer Repair
How do you remove the timer, dial assembly and replace Related ModelsKenmore 11092962100 WASHER DRYER LAUNDRY SYSTEMKenmore
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How to remove timer and replace
  #1 (permalink)
Old 10-12-2008, 06:41 PM
lash909 lash909 is offline
Junior Member
lash909 is on a distinguished road
Default How to remove timer and replace
Model Number: 11092592200   Brand: Kenmore   Age: More than 10 years
Related Models
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11095 CEILING FAN
Kenmore 11096195120 ELECTRIC DRYER
Kenmore 11096195500 ELECTRIC DRYER
Kenmore 11096195510 DRYER FEATURE SHEET
Kenmore 11096195520 ELECTRIC DRYER
Kenmore 11096195800 ELECTRIC DRYER
Kenmore 11096195810 DRYER FEATURE SHEET
Kenmore 11096195820 ELECTRIC DRYER
Kenmore 11096210100 DRYER-FEATURE SHEET
Kenmore 11096220100 DRYER-FEATURE SHEET
Kenmore 11096250100 DRYER-FEATURE SHEET
Kenmore 11096260100 DRYER FEATURE SHEET
Kenmore 11096263100 DRYER-FEATURE SHEET
Kenmore 11096263800 DRYER-FEATURE SHEET
Kenmore 11096264100 DRYER FEATURE SHEET
Kenmore 11096264800 DRYER FEATURE SHEET
Kenmore 11096271100 DRYER FEATURE SHEET
Kenmore 11096271600 DRYER FEATURE SHEET
Kenmore 11096271800 DRYER FEATURE SHEET
Kenmore 11096272000 ELECTRIC DRYER
Kenmore 11096272100 DRYER FEATURE SHEET
Kenmore 11096272600 DRYER FEATURE SHEET
Kenmore 11097091100 GAS DRYER
Kenmore 11097091300 GAS DRYER
Kenmore 11097091700 GAS DRYER
Kenmore 11097091800 GAS DRYER
Kenmore 11097093100 GAS DRYER
Kenmore 11097093300 GAS DRYER
Kenmore 11097093500 GAS DRYER
Kenmore 11097093700 GAS DRYER
Kenmore 11097093800 GAS DRYER
Kenmore 11097094100 GAS DRYER
Kenmore 11097094300 GAS DRYER
Kenmore 11097094500 GAS DRYER
Kenmore 11097094700 GAS DRYER
Kenmore 11097094800 GAS DRYER
Kenmore 11097195100 GAS DRYER
Kenmore 11097195110 DRYER FEATURE SHEET
Kenmore 11097195120 GAS DRYER
Kenmore 11097195500 GAS DRYER
Kenmore 11097195510 DRYER FEATURE SHEET
Kenmore 11097195520 GAS DRYER
Kenmore 11097195800 GAS DRYER
Kenmore 11097195810 DRYER FEATURE SHEET
Kenmore 11097195820 GAS DRYER
Kenmore 11097210100 DRYER-FEATURE SHEET
Kenmore 11097220100 DRYER-FEATURE SHEET
Kenmore 11097250100 DRYER-FEATURE SHEET
Kenmore 11097260100 DRYER FEATURE SHEET
Kenmore 11097264100 DRYER FEATURE SHEET
Kenmore 11097264800 DRYER FEATURE SHEET
Kenmore 11097271100 DRYER FEATURE SHEET
Kenmore 11097271600 DRYER FEATURE SHEET
Kenmore 11097271800 DRYER FEATURE SHEET
Kenmore 11097272100 DRYER FEATURE SHEET
Kenmore 11097272600 DRYER FEATURE SHEET
Kenmore 11097272800 DRYER SPECIFICATIONS
Kenmore 11097273100 DRYER FEATURE SHEET
Kenmore 11097273600 DRYER FEATURE SHEET
Kenmore 11097273800 DRYER FEATURE SHEET
Kenmore 11097274100 DRYER FEATURE SHEET
Kenmore 11097274600 DRYER FEATURE SHEET
Kenmore 11097274800 DRYER FEATURE SHEET
Kenmore 11097278100 DRYER FEATURE SHEET
Kenmore 11097278800 DRYER FEATURE SHEET
Kenmore 11097280100 DRYER FEATURE SHEET
Kenmore 110985000 SEARS DIRECT DISCHARGE WALL FAN
Kenmore 110985100 VERTICAL DISCHARGE FAN
Kenmore 11098518200 ELECTRIC DRYER
Kenmore 11098518210 ELECTRIC DRYER
Kenmore 11098518220 ELECTRIC DRYER
Kenmore 11098518230 COMPACT ELECTRIC DRYER
Kenmore 11098518400 ELECTRIC DRYER
Kenmore 11098518410 ELECTRIC DRYER
Kenmore 11098518420 ELECTRIC DRYER
Kenmore 11098518430 COMPACT ELECTRIC DRYER
Kenmore 110985200 SEARS HEATER/FAN/LIGHT
Kenmore 110985300 FAN/LIGHT
Kenmore 110985400 BULB HEATER/FANS
Kenmore 110985500 BULB HEATER/FANS
Kenmore 110985501 BULB HEATER/FAN
Kenmore 110985600 SEARS BATHROOM FANS
Kenmore 110985700 SEARS BATHROOM FANS
Kenmore 11098572200 ELECTRIC DRYER
Kenmore 11098572210 ELECTRIC DRYER
Kenmore 11098572400 ELECTRIC DRYER
  #2 (permalink)
Old 10-12-2008, 06:51 PM
Zanshin Zanshin is offline
Member
Zanshin is on a distinguished road
Default
Most can be removed by entering from the rear of console, remove screws holding sheet metal panel and you will see timer, knob slides off from the front, two screws hold timer in place in rear , replace one wire at a time.
  #3 (permalink)
Old 10-12-2008, 06:55 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
I do believe that the knob just pulls rite off, The timer may have 2 screws that need to be accessed from inside the console.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Unable to remove GE timer knob andyhutch Washer Repair 5 11-18-2009 03:43 PM
How to remove the timer from a Maytag Geo2495 Washer Repair 4 07-04-2009 05:49 AM
How do I remove large timer knob w/o breaking it? beaumart@plateautel.net Washer Repair 2 07-03-2008 04:44 PM
How to remove Control Panel to replace switch dan0409 Dishwasher Repair 0 02-08-2008 04:29 PM
Remove & Replace Motor aaronstampley Dishwasher Repair 1 11-02-2007 11:57 AM
