| » broken idler pulley spring |
Model Number: FWS235RFS5 Brand: Frigidaire Age: 1 - 5 years
1. will a broken idler pulley spring cause the drum not to spin up to speed? 2. if so how hard is it to replace? I have pulled the front cover and the belt tensioner just flops back and forth. Will the new spring fix the problem? I do have some mechanical background. What is the best way to replace this? thanks
if there is no tension on the belt it wont tumble the sping is easy there are two holes each end of the spring hooks into its sometimes easier from access panel in lower left corner from rear to secure spring
| Display Modes | |
| idler pulley spring placement | mikeniel | Dryer Repair | 2 | 02-06-2010 06:41 AM |
| Dryer idler pulley spring mount? | PatrickJ | Dryer Repair | 4 | 05-05-2009 06:11 AM |
| belt broken and idler pulley off | lauren | Dryer Repair | 1 | 11-30-2008 07:05 AM |
| installing idler pulley | darberryman | Dryer Repair | 2 | 11-08-2007 05:52 AM |
| Idler Pulley | Jeremy | Dryer Repair | 2 | 08-03-2007 05:18 PM |
