| » washer will not spin out all the water in the last spin |
Model Number: 23832100 Brand: Kenmore Age: 5 - 10 years
What part do I need to Buy for my Kenmore washer 80 series Heavy Duty . My washer will not spin all of the water in the last spin. Is it the brake
If you have bad brake shoes, a new clutch will wear out soon, unless the motor burns out first!
Crunch into the search window, "replacing direct drive brake shoes", If it fails the test with the tranny coupler, you have bad brake shoes.
__________________
- Last edited by richappy : 10-12-2008 at 10:01 AM. |
Richappy is correct, HOWEVER, I have been working on these washers since they were introduced in 1981. I have NEVER had to replace "Brake Shoes" I think you will find that replacing the clutch will take care of your problem. Have a great day!!!!
I also have been fixing these since then and recently have seen a lot of the "newer" ones with really BAD problems with dragging brake shoes. I have seen motors burn out or motor epoxy failures jamming the bearings.
The brake shoe rollers wear out because they now never oil them in production!!
__________________
| Display Modes | |
| washer will not spin out all the water in the last spin | myesshowme | Washer Repair | 1 | 10-11-2008 05:21 PM |
| My Washer Will Not Spin Out Water Or Rinse. | FootballMOM75 | Washer Repair | 1 | 08-25-2008 06:34 PM |
| Washer will not pump out water in spin | Blue Bear | Washer Repair | 0 | 07-24-2008 06:08 AM |
| Washer will not spin or pump out water | mcwasher | Washer Repair | 3 | 07-23-2008 11:28 AM |
| Washer won't spin or pump water out | nikki afinowicz | Washer Repair | 0 | 12-09-2007 07:41 AM |
