Hello:
Looking for a little guidance on my Washer. Debating on fixing or replacing. Works in all cycles exept...fills okay, agitates, pumps out but....it seems when the timer moves into the "spin" - it seems to bind up. I can free it up by manually by rotating the basket.....but it s=doesn't sound good - clunky. Any ideas? Transmission? Thanx George
See if replacing the belt will fix it.
It could be the clutch assembly, but given the cost of parts and what I consider the general unreliability of these GE models I would replace it.
