I have a GE whdsr316g0ww and, like others, yesterday it decided to stop agitating/spinning. So far I have: Checked for the LED, no light. Unwrapped and checked the fuse that's grouped in the wire harness, looks intact. Bypassed the lid switch, still nothing. So I'm at a loss. If anyone has any ideas, suggestions or sees something I may have missed pleased feel free to let me know.
Thanks sid, I read through the link. I disconnected the fuse, checked for conductivity and it is fine. As is the lid switch. I still don't have any LED signal on the motor. Any suggestions or things I may have missed?
Some people have a hard time finding the light so try reseting it as suggested on that page even if you don't see the light.
If that doesn't work I belive you have a bad motor assuming you have voltage comming to the motor. There should be 110V from the white/red wire and the red/black wire anytime. There should be 110V from the white/red and the orange with the lid closed. If all is good there the motor is bad.
