Discuss
Frigidare Washer issues
 in
Washer Repair
First thing we noticed was the clothes were coming out really wet. Pretty much as if you just put them
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidare Washer issues
  #1 (permalink)
Old 10-09-2008, 04:49 PM
Torwadeo Torwadeo is offline
Junior Member
Torwadeo is on a distinguished road
Default Frigidare Washer issues
Brand: Frigidaire   Age: 5 - 10 years
First thing we noticed was the clothes were coming out really wet. Pretty much as if you just put them in a tub of water and took them out.
So tonight I put the washer on final spin and it was spinning really fast but making really loud banging and squeaking sounds.
Is this something that is worth calling for service or should I just get a new washer. It came with our house which we had for 3 years. It looked fairly new when we got it so I would say it is like 5 or 6 years old at the most.
Thanks - Also money is tight so if I don't need a new washer I am hoping this one can be fixed for under $200
  #2 (permalink)
Old 10-09-2008, 04:52 PM
Junior Member
Default
One other note. In the past you could open the door and spin the inside by hand fairly easy but now it is really hard to spin.
  #3 (permalink)
Old 10-09-2008, 05:08 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
If you post a model# it would help, Is it a top loader? or Front loader??? Check around the top of the tub to see if anything is stuck between the tubs!!!
  #4 (permalink)
Old 10-09-2008, 05:18 PM
Junior Member
Default
Model # GTLIF1040AS-WW Gallery - Front loader
  #5 (permalink)
Old 10-09-2008, 06:30 PM
Senior Expert
APP Volunteer
Default
I will BET that the tub spider is broken, Its the part of the tub that has the axle that the tub rotates on. They have a corroision problem and fail after 6-10 yrs. The GOOD news is: The tub has a 25 yr warrantee (if you have a dealer repair it) Check with your local FRIGIDAIRE DEALER!!!
  #6 (permalink)
Old 10-11-2008, 05:37 PM
Junior Member
Default
So I had someone come out and take a look at my washer. He said a bearing had to be replaced. Said to fix it he would have to take the entire washer apart and it would be really labor intensive. Quoted me $750 plus and told me go out and buy a Whrilpool or a Maytag. Does the above diagnosis sound correct or did he just not want to be bothered fixing my machine? Thanks
I think he said it was the rear bearing, if that means anything to anyone.
  #7 (permalink)
Old 10-11-2008, 06:57 PM
Senior Expert
APP Volunteer
Default
He is a LAZY S.O.B. and a THIEF!!!!! The wash basket would be free, The outer rear shell(outer tub with brg. and seal included) is AROUND $240. I change the two parts in 1.5 hrs. SO, $500 bucks for a job that takes 1.5 hrs is pretty darn good money in MY book!!!!! Now, with this said, you can replace that washer for $569.00, If you want to replace it with a new FL washer,(and don't want to spend alot of money) Get another one just like the one you have. (You could NOT GIVE ME a wpool-Maytag FL washer rite now) With this washer you have now, were you using He detergent?? 1/2 cap full or less???
  #8 (permalink)
Old 10-11-2008, 07:35 PM
Junior Member
Default
The washer came with our house and we had never had any experince with front loaders so we just used regular detergent in it. I am thinking this may have had something to do with our issue. We are looking at getting a top loader for a replacement and saw a Whirlpool for under $400. Thanks for your posts. You have been helpful
Also, the guy said he would have to take the washer into the shop because he could not fix it at my house.
  #9 (permalink)
Old 10-12-2008, 11:25 AM
Senior Expert
APP Volunteer
Default
A Whirlpool top loader would be a GREAT CHOICE!!!! Good luck!!!!
  #10 (permalink)
Old 10-12-2008, 12:28 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Just make sure you get a Whirlpool direct drive, stay away from the Calypso or Cabriol!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidare / Sears Part Scotts Appliance Washer Repair 2 09-22-2008 02:22 PM
Frigidare dishwasher dead styx1 Dishwasher Repair 0 07-13-2008 07:26 AM
Frigidare washer won't spin jordan1957 Washer Repair 8 11-05-2007 06:52 PM
Frigidare dryer with no heat bit1001001 Dryer Repair 1 11-02-2007 03:34 PM
Frigidare Display dim, not bright, but functional Hill_Cumorah Oven Repair (including Ranges and Cooktops) 1 08-04-2007 12:56 AM
