Discuss
Timer does not advance
 in
Washer Repair
The washer fills up and stays on the same cycle until it is moved to the next by hand. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Timer does not advance
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-25-2007, 02:03 PM
Lloyd Kneller Lloyd Kneller is offline
Junior Member
Lloyd Kneller is on a distinguished road
Exclamation Timer does not advance
Model Number: LW7563W2   Brand: Amana   Age: More than 10 years
The washer fills up and stays on the same cycle until it is moved to the next by hand. I am trying to replace the timer and I am having trouble separating the dial from the time. How do I go about separating the dial from the timer?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-26-2007, 02:18 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
The knob just unscrews after pushing it in. If not, you have a stripped plastic part that couples the shaft to the big plastic cam. Will need to pull timer cover and jam plastic cam to remove.
I used to have a bucket of used timers to repair this.If you have a plastic timer, just pull out the plastic tab in the back of timer, then knob pulls out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
range/timer ewallen Oven Repair (including Ranges and Cooktops) 0 09-24-2007 02:35 PM
Cycle won't advance dbarnard Washer Repair 0 09-24-2007 09:37 AM
Timer again??? 4dugnlee Washer Repair 8 08-17-2007 06:45 AM
Whirlpool washer will not advance cycles GARY H Washer Repair 0 08-14-2007 06:18 PM
Timer will not turn off rb8941 Dryer Repair 1 08-01-2007 10:11 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
