Hello, My washer is going on 4 years old. Well yesterday I was doing a load and the machine filled up with water and now im getting an error code LD well I looked it up and it says (long to drain) I saw several others post that they had the same problem and it was the pump. All it does is hummm and wont stop until I unplug it. So many said they had bad pumps that I thought I would get online and order one. Well it shows two different pumps and I have no clue which one and I would kind like to make sure im on the right track. Thanks
Originally Posted by: Medster Hello, My washer is going on 4 years old. Well yesterday I was doing a load and the machine filled up with water and now im getting an error code LD well I looked it up and it says (long to drain) I saw several others post that they had the same problem and it was the pump. All it does is hummm and wont stop until I unplug it. So many said they had bad pumps that I thought I would get online and order one. Well it shows two different pumps and I have no clue which one and I would kind like to make sure im on the right track. Thanks Medster, Yes, You are most likely correct, You may have a clogged or inop pump. There are two water pumps on this style unit , a "Drain" pump, and a "Recirculation" pump. In your case you would order the drain pump. (click on number for information) Part number: AP4365341
Good Luck, :cool: :cool: :cool:
