Discuss
new part not matching old part
 in
Washer Repair
My Ge was bought in 1991. It filled up with water but would not function other wise. I figured out
Appliance Repair Forum > Appliance Repair Help > Washer Repair » new part not matching old part
  #1 (permalink)
Old 09-21-2010, 09:25 AM
Junior Member
hortlady is on a distinguished road
Post new part not matching old part
Model Number: WWA8608MALWH   Brand: GE   Age: More than 10 years
My Ge was bought in 1991. It filled up with water but would not function other wise. I figured out I needed a lid switch. GE no longer made it so I could not get it locally. AppliancePartsPros.com had the WH12X494 part which was made by someone other than GE. Fine I thought. I ordered it.
When I went to work on the washer I found the old part had 2 brass areas where wire clips were attached. The new part has 3 brass areas where wire clips attach. There are 2 brass areas which extend straight out from the switch at either end, the new switch as an additional brass area that bends up at an angle to attach a wire clip or connector to it.
Will this part work?
What do I do about the extra brass area which would accept a wire clip or connector? I don't have a wire to connect to it.
hortlady
Ads By Google
Related Models
General Electric WWA8608MXL Washer
General Electric WWA8610SALAA Washer
General Electric WWA8610SALWW Washer
General Electric WWA8610SBLAA Washer
General Electric WWA8610SBLWW Washer
General Electric WWA8616MAL Washer
General Electric WWA8616RBL Washer
General Electric WWA8620MAL Washer
General Electric WWA8620RBL Washer
General Electric WWA8620SALAA Washer
General Electric WWA8620SALWW Washer
General Electric WWA8620SBLAA Washer
General Electric WWA8620SBLWW Washer
General Electric WWA8620SCLAA Washer
General Electric WWA8620SCLWW Washer
General Electric WWA8630SALAA Washer
General Electric WWA8630SALWW Washer
General Electric WWA8630SBLAA Washer
General Electric WWA8630SBLWW Washer
General Electric WWA8648MAL Washer
General Electric WWA8650SALAA Washer
General Electric WWA8650SALWW Washer
General Electric WWA8650SBLAA Washer
General Electric WWA8650SBLWW Washer
General Electric WWA8657MAL Washer
General Electric WWA8657RBL Washer
General Electric WWA8689MAL Washer
General Electric WWA8689RBL
General Electric WWA8689RBLAA Washer
General Electric WWA8689RBLWW Washer
General Electric WWA8695SALAA Washer
General Electric WWA8695SALWW Washer
General Electric WWA8695SBLAA Washer
General Electric WWA8695SBLWW Washer
General Electric WWA8700LAL Washer
General Electric WWA8700LBL Washer
General Electric WWA8800MAL Washer
General Electric WWA8800RBL
General Electric WWA8800RBLAA Washer
General Electric WWA8800RBLWW Washer
General Electric WWA8806MAL Washer
General Electric WWA8808MAL Washer
General Electric WWA8810MAL Washer
General Electric WWA8810RBL Washer
General Electric WWA8816RBL Washer
General Electric WWA8819MAL Washer
General Electric WWA8827MAL Washer
General Electric WWA8829RBLWW Washer
General Electric WWA8836MAL Washer
General Electric WWA8837RBL Washer
General Electric WWA8849RBLWW Washer
General Electric WWA8850RBL
General Electric WWA8850RBLAA Washer
General Electric WWA8850RBLWW Washer
General Electric WWA8850SALAD Washer
General Electric WWA8850SALHA Washer
General Electric WWA8850SALWH Washer
General Electric WWA8857RBL Washer
General Electric WWA8858MAL Washer
General Electric WWA8866RBL Washer
General Electric WWA8869MAL Washer
General Electric WWA8876MAL Washer
General Electric WWA8879RBLWW Washer
General Electric WWA8887MAL Washer
General Electric WWA8887RBL Washer
General Electric WWA8890RBL
General Electric WWA8890RBLAA Washer
General Electric WWA8890RBLWW Washer
General Electric WWA8896RBL Washer
General Electric WWA8898MAL Washer
General Electric WWA8900SALAA Washer
General Electric WWA8900SALWW Washer
General Electric WWA8935SALAA Washer
General Electric WWA8935SALWW Washer
General Electric WWA8950SALAA Washer
General Electric WWA8950SALWW Washer
General Electric WWA8955SALAA Washer
General Electric WWA8955SALWW Washer
General Electric WWA8990SALAA Washer
General Electric WWA8990SALWW Washer
General Electric WWA8990SCLAA Washer
General Electric WWA8990SCLWW Washer
General Electric WWA8995SALAA Washer
General Electric WWA8995SALWW Washer
General Electric WWA9800MAL Washer
General Electric WWA9800RBL Washer
General Electric WWA9850MAL Washer
General Electric WWA9850RBL Washer
General Electric WWA9890MAL Washer
General Electric WWA9890RBL Washer
General Electric WWA9895SALAA Washer
General Electric WWA9895SALWW Washer
General Electric WWC6620ABL Washer
General Electric WWC6622ABL Washer
General Electric WWC6630ABL Washer
General Electric WWC6630ACL Washer
General Electric WWC6840ABL Washer
General Electric WWC7000FAL Washer
General Electric WWC7000FBL Washer
General Electric WWC7000FCL Washer
General Electric WWC7190CAL Washer
General Electric WWC7190CBL Washer
General Electric WWC7500FAL Washer
General Electric WWC7500FBL Washer
General Electric WWC7500FCL Washer
General Electric WWC7500FDL Washer
General Electric WWC8000FAL Washer
General Electric WWC8000FBL Washer
General Electric WWC8000FCL Washer
General Electric WWC8000FDL Washer
General Electric WWC8000MAL Washer
General Electric WWC8000PAL Washer
General Electric WWC8000PBL Washer
General Electric WWC8000RAL Washer
General Electric WWC8000SAL Washer
General Electric WWC8100FAL Washer
General Electric WWC8100FBL Washer
General Electric WWC8100FCL Washer
General Electric WWC8100FDL Washer
General Electric WWC8400PBL Washer
  #2 (permalink)
Old 09-21-2010, 10:01 AM
Senior Member
applianceman is on a distinguished road
Default
What you got is a universal switch, which will always have three terminals. What you do is plug the two wires into the terminals marked No and C and leave the other one alone. The switch will work.
Clothes Washer Repair Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacement part for discontinued part #9741559 James F Morin Dishwasher Repair 2 06-03-2009 12:06 PM
Part for GE dishwasher is different from existing part kevinpvb Dishwasher Repair 0 06-03-2009 12:04 PM
Need discontinued part for Jenn-Air range. Part #74002173 Clock component Sandi Gainey Oven Repair (including Ranges and Cooktops) 0 03-25-2009 05:33 PM
part recd not matching diagram krl42 Dishwasher Repair 1 02-26-2009 03:57 PM
Freezer part cold, fridge part warm keithpar Refrigerator & Freezer Repair 1 10-08-2007 03:21 AM
