KendraSue
#1 Posted : Monday, September 20, 2010 9:27:46 AM(UTC)
KendraSue
Digital Panel works. None of the Cycles work. :( Error code E6E. Can you help me?
sidfink43
#2 Posted : Tuesday, September 21, 2010 5:59:34 PM(UTC)
sidfink43
Look inside the lower service panel and you will find some tech notes that will give you an explanation of the error codes and a some troubleshooting techniques that should help.
I think your error code may be E5E in which case the problem can be in the speed control board, the wiring between the speed control board and the main board or the main board itself. This is a difficult problem to diagnose and you may end up just having to replace parts to fix it.
Sorry not to be more definitive, this is the way of the world with microprocessor controls in washers.
KendraSue
#3 Posted : Monday, September 27, 2010 7:05:52 AM(UTC)
KendraSue
Thank you so much for responding. I contacted Frigidaire and told them their washing machine was only 3 yrs old and was used very little. Because the warranty had expired they told me they could not do anything. I kept pursuing the issue and now they have agreed to pay for parts and labor BUT I have to have one of their certified tech's to make the diagnosis and I will have to pay for that service call. Do you think it's worth it?
#4 Posted : Monday, September 27, 2010 6:06:43 PM(UTC)
If you failed to use the special HE soap, your seals and bearings in the tub may have failed and caused the speed control board to fail. Thus, just replacing the speed control board will not prevent it from failing again. If you turn the basket and you hear bearings, then it probably would not be worth repairing.
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
LTF2940FE0 FRIGIDAIRE FRONT LOAD WASHER (Washer Repair)
by Guest 9/8/2022 9:06:55 PM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
fRIDGIDAIRE AFFINITY FRONT LOAD WASHER WILL NOT STAY IN LOCK MODE (Washer Repair)
by Guest 2/21/2022 3:21:13 PM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Samsung front load washer rotor cover hitting (Washer Repair)
by Kickerjb44 12/19/2021 3:31:57 PM(UTC)
Samsung Front Load Washer Gets Stuck at 1 Minute (Washer Repair)
by Radar314 11/12/2021 5:45:08 AM(UTC)
maytag 2000 front load washer (Washer Repair)
by crazyeyebrad 10/30/2021 7:34:44 AM(UTC)
WF56H9100AG/A2 Samsung Front Load Washer Displays 4e / LE error code (Washer Repair)
by dcgtechnologies 10/1/2021 9:38:54 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
