Discuss
Washer timer won't advance
 in
Washer Repair
I have an old LA 212 Maytag washer, the timer stopped advancing on the regular cycle so we started using
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer timer won't advance
  #1 (permalink)
Old 09-20-2010, 07:26 AM
Junior Member
jbuckingham is on a distinguished road
Default Washer timer won't advance
Model Number: LA 212   Brand: Maytag   Age: More than 10 years
I have an old LA 212 Maytag washer, the timer stopped advancing on the regular cycle so we started using the delicates and knit cycle instead. I purchased a new timer from this site and with the new timer in place the washer runs but will not advance at all. In order for it to progress through the the cycle I had to move the knob by hand. I'm wondering if I have a bad new timer. I took the new one out and replaced it with the old one, the washer cycled fine through the delicates cycle. Please advise on a way to test the new timer to see if it is broken.
Related Models
 LA090CP Air Conditioner
Maytag LA104 WASHER-TOP LOADING
Maytag LA105 WASHER-TOP LOADING
Maytag LA110 WASHER-TOP LOADING
Maytag LA112 WASHER-TOP LOADING
 LA120CP Air Conditioner
 LA121CNM.ANCAEUS Air Conditioner
 LA121CNP.ANCAEUS Air Conditioner
Amana LA12300.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA12600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA12610.A MWAVE - FAMILY SIZE (60 HZ)
 LA141CP Air Conditioner
Amana LA15300.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA15500.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA15600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA15610.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA15700.A MWAVE - FAMILY SIZE (60 HZ)
Maytag LA180 WASHER-TOP LOADING
 LA180CP Air Conditioner
Maytag LA181 WASHER-TOP LOADING
 LA181CNW.ANCAEUS Air Conditioner
Maytag LA182 WASHER-TOP LOADING
Maytag LA183 WASHER-TOP LOADING
Maytag LA190 WASHER-TOP LOADING
Maytag LA1910 WASHER-TOP LOADING
Admiral LA2000 DRYER- ELE
Admiral LA2000A DRYER- ELE
Admiral LA2000H DRYER- ELE
Maytag LA207 WASHER-TOP LOADING
Maytag LA209 WASHER-TOP LOADING
Maytag LA209S WASHER-TOP LOADING
Maytag LA210 WASHER-TOP LOADING
Maytag LA210S WASHER-TOP LOADING
Maytag LA211 WASHER-TOP LOADING
Maytag LA211S WASHER-TOP LOADING
Maytag LA212 WASHER-TOP LOADING
Maytag LA212S WASHER-TOP LOADING
Amana LA22391.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA23400.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA23400.B MWAVE - FAMILY SIZE (60 HZ)
Amana LA23500.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA23500.B MWAVE - FAMILY SIZE (60 HZ)
Amana LA23600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA23600.B MWAVE - FAMILY SIZE (60 HZ)
Amana LA23700.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA23700.B MWAVE - FAMILY SIZE (60 HZ)
Amana LA25700.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA25700.B MWAVE - FAMILY SIZE (60 HZ)
Amana LA25800.A MWAVE - FAMILY SIZE (60 HZ)
Amana LA25800.B MWAVE - FAMILY SIZE (60 HZ)
Maytag LA25CM MAYTAG LAUNDRY (WASHER)
Maytag LA25CME MAYTAG LAUNDRY (WASHER)
Maytag LA25CS MAYTAG LAUNDRY (WASHER)
Maytag LA25CT MAYTAG LAUNDRY (WASHER)
Maytag LA26CD MAYTAG LAUNDRY (WASHER)
Maytag LA26CDC MAYTAG LAUNDRY (WASHER)
Frigidaire LA271EXW1 Wwh(v1) / Top Loading Agitator Washer
Frigidaire LA271EXW2 Wwh(v2) / Top Loading Agitator Washer
Frigidaire LA271JXW3 Wwh(v0) / Top Loading Washer
Frigidaire LA271JXW4 Wwh(v1) / Top Load Washer
Frigidaire LA271LXW1 Wwh(v1) / Top Load Washer
Frigidaire LA271MXD1 Wwh(v4) / 27 " Washer
Frigidaire LA271MXD2 Wwh(v4) / 27 " Washer
Frigidaire LA271MXW1 Wwh(v3) / 27 " Washer
Frigidaire LA271MXW2 Wwh(v3) / 27 " Washer
Frigidaire LA271MXW3 Wwh(v1) / 27 " Washer
Frigidaire LA271MXW4 Wwh(v1) / 27 " Washer
Frigidaire LA272AXW1 Wwh(v1) / 27 " Washer
Maytag LA282 WASHER-TOP LOADING
Maytag LA283 WASHER-TOP LOADING
Maytag LA284 WASHER-TOP LOADING
Frigidaire LA300AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA300AXD2 Wwh(v6) / 27 " Washer
Frigidaire LA300AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA300AXW2 Wwh(v5) / 27 " Washer
Frigidaire LA300MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA300MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA300MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA300MXW2 Wwh(v1) / 27 " Washer
Maytag LA302 WASHER-TOP LOADING
Maytag LA305 WASHER-TOP LOADING
Maytag LA308 WASHER-TOP LOADING
Maytag LA308S WASHER-TOP LOADING
Maytag LA310 WASHER-TOP LOADING
Maytag LA310S WASHER-TOP LOADING
Maytag LA312 WASHER-TOP LOADING
Maytag LA312S WASHER-TOP LOADING
Whirlpool LA3300XPW0
Whirlpool LA3300XPW1
Whirlpool LA3300XPW3
Whirlpool LA3300XPW4
Whirlpool LA3300XSW0
Whirlpool LA3400XMW0
Whirlpool LA3400XMW1
Whirlpool LA3400XMW2
Whirlpool LA3400XMW3
Whirlpool LA3400XPW0
Whirlpool LA3400XPW1
Whirlpool LA3400XPW3
Whirlpool LA3400XPW4
Whirlpool LA3400XSW0
Whirlpool LA3400XSW1
Whirlpool LA3400XTW0
Whirlpool LA3400XTW1
Whirlpool LA3800XKW1
Whirlpool LA3800XMW0
Whirlpool LA3800XPW0
Whirlpool LA3800XPW1
Whirlpool LA3800XSW0
Maytag LA382 WASHER-TOP LOADING
Maytag LA390 WASHER-TOP LOADING
Maytag LA3910 WASHER-TOP LOADING
Whirlpool LA4000XKW0
Frigidaire LA400AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA400AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA400AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA400AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA400EXD3 Wwh(v1) / Top Loading Washer
Frigidaire LA400EXF3 Wwh(v2) / Top Loading Washer
Frigidaire LA400EXH3 Wwh(v3) / Top Loading Washer
  #2 (permalink)
Old 09-20-2010, 08:08 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
J,
It would require a multi meter , and the wiring diagram(timer cam chart) that's located in the control console.
A couple of Questions,
Before you replaced the timer, where did the dial stop advancing ?
Are you sure you put the correct wire(s) on the correct terminals on the new timer ?
(that's the most common problem, some terminals are not in the same location on a new timer).
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-20-2010, 08:45 AM
Junior Member
Default
The washer would advance in the regular cycle using the old timer up to the point of filling for the final rinse. With the new timer, the timer never moved beyond the initial filling of the wash drum. Instead the washer would fill up then drain, then fill up again. I had to advance the timer manually to get it to move through the rest of the cycle. The pointer on the timer did not move through the entire process. I tried using the new timer in the delicate cycle as well, but it did the same thing. I'm pretty sure I got the wiring right as the numbers are printed on the wires.
  #4 (permalink)
Old 09-20-2010, 11:43 AM
Senior Expert
Default
J,
Are you sure your drain hose is high enough,( the loop / hook of the line should be at least as high as the top of the machine or higher, it should be 37 in. off the floor). It sounds like the unit is not filling proper due to a low drain hose heigth or syphonning because the hose is sealed to the drain pipe and has no back up air to break the vaccuum on the drain system.
It's not that common to have 2 components with very similar or same complaints, without there being something else wrong.
As long as you're sure you have the numberred wires on the proper numberred terminals, then I can only guess and think you may have gotten a bad timer in the box, Anything is possible.
If your drain hose heigth is correct and your original timer works semi proper, it may be time to check the air dome hose for clogs or pin holes or a bad water level switch.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer timer will not advance. Chumlord Washer Repair 9 01-24-2011 01:02 PM
washer fills, timer doesn't advance, nor does it agitate, spin, or drain threads68 Washer Repair 3 01-17-2010 01:47 AM
Timer won't advance. irhoghead Dryer Repair 1 01-09-2010 07:52 PM
Frigidaire washer timer won't advance myura46 Washer Repair 1 12-22-2009 04:27 PM
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 ambsdr4god Washer Repair 1 11-09-2009 07:21 AM
