Discuss
Pump Drains Tub But No Spin Cycle
 in
Washer Repair
Problem: Tub won't spin to wring out load Discovered problem when the washer was supposed to be in the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Pump Drains Tub But No Spin Cycle
  #1 (permalink)
Old 09-25-2007, 09:18 AM
matt b matt b is offline
Junior Member
matt b is on a distinguished road
Default Pump Drains Tub But No Spin Cycle
Model Number: LA5668XTWO   Brand: Whirlpool   Age: 5 - 10 years
Discovered problem when the washer was supposed to be in the final spin cycle. The water was pumped out; the motor was running; but the tub was not moving.
I shut the unit off and then retried a few times to see if it would spin...no luck, it just pumped out the remaining water in the tub. Next I tried to see what would happen at various points of a complete wash cycle...nothing happens. I assume nothing can happen because there is no water in the tank!
Any help or ideas out there?
Thank you,
Matt
Related Models
Whirlpool LA5700XKW0
Whirlpool LA5700XMW0
Whirlpool LA5700XMW1
Whirlpool LA5700XPW0
Whirlpool LA5700XPW1
Whirlpool LA5700XPW3
Whirlpool LA5700XPW4
Whirlpool LA5700XPW5
Whirlpool LA5700XPW6
Whirlpool LA5700XSW0
Whirlpool LA5700XSW1
Whirlpool LA5700XSW2
Whirlpool LA5700XTF0
Whirlpool LA5700XTF1
Whirlpool LA5700XTG0
Whirlpool LA5700XTG1
Whirlpool LA5700XTM0
Whirlpool LA5700XTM1
Whirlpool LA5700XTN0
Whirlpool LA5700XTN1
Whirlpool LA5700XTW0
Whirlpool LA5700XTW1
Whirlpool LA5705XKW0
Whirlpool LA5705XMW0
Whirlpool LA5705XMW1
Whirlpool LA5705XTF0
Whirlpool LA5705XTF1
Whirlpool LA5705XTF2
Whirlpool LA5705XTG0
Whirlpool LA5705XTG1
Whirlpool LA5705XTG2
Whirlpool LA5705XTM0
Whirlpool LA5705XTM1
Whirlpool LA5705XTM2
Whirlpool LA5705XTN0
Whirlpool LA5705XTN1
Whirlpool LA5705XTN2
Whirlpool LA5705XTW0
Whirlpool LA5705XTW1
Whirlpool LA5705XTW2
Whirlpool LA5705XWF0
Whirlpool LA5705XWG0
Whirlpool LA5705XWM0
Whirlpool LA5705XWN0
Whirlpool LA5705XWW0
Whirlpool LA5710XPW0
Whirlpool LA5710XPW1
Whirlpool LA5710XPW3
Whirlpool LA5715XPW0
Whirlpool LA5715XPW1
Whirlpool LA5715XPW3
Whirlpool LA5720XTF0
Whirlpool LA5720XTG0
Whirlpool LA5720XTM0
Whirlpool LA5720XTN0
Whirlpool LA5720XTW0
Whirlpool LA5800XKW0
Whirlpool LA5800XKW1
Whirlpool LA5800XMW0
Whirlpool LA5800XPW0
Whirlpool LA5800XPW1
Whirlpool LA5800XSW0
Whirlpool LA5800XSW1
Whirlpool LA5800XTF0
Whirlpool LA5800XTF1
Whirlpool LA5800XTG0
Whirlpool LA5800XTG1
Whirlpool LA5800XTM0
Whirlpool LA5800XTM1
Whirlpool LA5800XTN0
Whirlpool LA5800XTN1
Whirlpool LA5800XTW0
Whirlpool LA5800XTW1
Whirlpool LA5805XKW0
Whirlpool LA5805XKW1
Whirlpool LA5805XMW0
Whirlpool LA5805XPW0
Whirlpool LA5805XPW1
Whirlpool LA5880XKW0
Whirlpool LA5880XKW1
Whirlpool LA5880XKW2
Whirlpool LA5885XKW0
Whirlpool LA5885XKW1
Maytag LA590 Washer - Top Loading
Whirlpool LA5900XSW0
Whirlpool LA5900XSW1
Maytag LA590T Washer - Top Loading
Maytag LA5910 Washer - Top Loading
Whirlpool LA5950XSW0
Whirlpool LA6000XPW0
Whirlpool LA6000XPW1
Whirlpool LA6000XPW2
Whirlpool LA6000XPW3
Whirlpool LA6000XPW4
Whirlpool LA6000XPW5
Whirlpool LA6000XSW0
Frigidaire LA600AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA600AXD2 Wwh(v6) / 27 " Washer
Frigidaire LA600AXD3 Wwh(v1) / 27 " Washer
Frigidaire LA600AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA600AXW2 Wwh(v5) / 27 " Washer
Frigidaire LA600AXW3 Wwh(v2) / 27 " Washer
Frigidaire LA600EXD3 Wwh(v11) / Top Loading Washer
Frigidaire LA600EXF3 Wwh(v12) / Top Loading Washer
Frigidaire LA600EXH3 Wwh(v13) / Top Loading Washer
Frigidaire LA600EXV3 Wwh(v14) / Top Loading Washer
Frigidaire LA600EXW3 Wwh(v15) / Top Loading Washer
Frigidaire LA600JXD3 Wwh(v1) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXD4 Wwh(v6) / Top Load Washer
Frigidaire LA600JXD5 Wwh(v3) / Top Load Washer
Frigidaire LA600JXF3 Wwh(v2) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXF4 Wwh(v7) / Top Load Washer
Frigidaire LA600JXH3 Wwh(v3) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXH4 Wwh(v8) / Top Load Washer
Frigidaire LA600JXV3 Wwh(v4) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXV4 Wwh(v9) / Top Load Washer
Frigidaire LA600JXW3 Wwh(v5) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXW4 Wwh(v10) / Top Load Washer
Frigidaire LA600JXW5 Wwh(v4) / Top Load Washer
Frigidaire LA600MXD1 Wwh(v6) / 27 " Washer
  #2 (permalink)
Old 09-26-2007, 03:40 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You have a busted coupler, just remove front panel and motor. You will need to replace the motor coupler. Click on your model # above to order it.
__________________
  #3 (permalink)
Old 09-26-2007, 05:51 AM
Junior Member
Default
Good morning Richappy,
Thank you for the advice. Fortunately, it is an inexpensive part.
Matt B
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No spin on regular cycle, others work klawson Washer Repair 2 12-05-2007 03:58 PM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
After wash cycle will not drain and spin out IndianaPanda Washer Repair 0 08-08-2007 01:15 PM
Washer will not spin but drains, etc. xevier69 Washer Repair 0 07-31-2007 09:05 AM
Niosy spin cycle and leak jpcamping Washer Repair 1 07-27-2007 12:02 PM
