| » washer stops at different cycles |
Model Number: gsx9885jq0 Brand: Whirlpool Age: 5 - 10 years
The washer stop at different cycles sometime it will stop at the wash and sometimes it stops at the rinse cycle there is no motor sound or any sound other than the contact clicking on the control board is this a motor coupling problem or is this something wrong on the control board? If you let the washer set for a couple of hours and take it to the spin cycle it will drain and spin!!!!!!!!!!!!!!!!!!!!!!!
This washer has a control board model#AP3855067 it does not have a control timer like the old style washer that you are thinking of so any more suggestions? The motor in the spin cycle is pulling about 8.5 amps. The motor in the wash cycle is pulling 9.0 amps this is well with in the the limits for the limits on the motor tag. I'm thinking that I have a bad control board?
When it fails, select drain and tell us what it does. If motor will not run, you probably have a bad/overheating motor, or an intermittent wire at the motor connector.
I usually check control module voltage out to the motor when it fails. No voltage there means module is failing, or power to it. Get your parts by clicking on your model# above.
__________________
The washer stop at different cycles sometime it will stop at the wash and sometimes it stops at the rinse cycle there is no motor sound or any sound other than the contact clicking on the control board is this a motor coupling problem or is this something wrong on the control board? If you let the washer set for a couple of hours and take it to the spin cycle it will drain and spin!!!!!!!!!!!!!!!!!!!!!!! we just got this cyles is it a lemon
We just got cyles washer when i do heavy loads it just keep running and not doing any thing |
| Display Modes | |
| maytag washer stops during cycles | wharkins | Washer Repair | 1 | 07-23-2009 04:45 PM |
| Bosch SMU 7054uc runs all cycles never stops | lopezgayle | Dishwasher Repair | 1 | 04-02-2009 12:14 PM |
| Washer stops at rinse cycles | Aubriella | Washer Repair | 4 | 12-06-2008 09:28 AM |
| Washer Not Going Thru Most Cycles | ncnicholson | Washer Repair | 3 | 11-29-2007 08:17 PM |
| stops on heating delay between cycles | scoot | Dishwasher Repair | 1 | 09-13-2007 02:14 AM |
