| » Kenmore 80 Series Clunky, Wont Drain or Spin |
Model Number: 110.29882890 Brand: Kenmore Age: 1 - 5 years
The washer will go through the wash cycle okay but it will not drain or spin. There is a very slight burning smell (almost like burning rubber). I think the timer works...because it will proceed until the drain/spin cycle but when it get to the drain cycle, it acts like the motor is overloaded and it will not spin. Consequently, after 5-10 seconds of trying, the motor kicks off and the washer is completely non-functioning. After a cool down period of 5-10 minute, the motor will reset and will agitate (wash) but the tub needs a little manual help to get it started. As soon as the cycle reaches the drain/spin cycle, it just gives up and the motor kicks off entirely. The water will not drain. Also, when the washer is in the wash agitation cycle there is now a slight clunking noise as if the motor/tub is not staying engaged.
Possibilities from reading other links don't seem to compute.... Drain/Water Pump??: Would this also cause the slight clunking I hear while in agitation mode and the need to get the tub started with some manual help? Safety Switch on Lid?: Wouldn't it still drain the water - just not spin? Motor?: The motor seems to work strongly in agitation mode once it is egaged. Timer?: Timer seems to be asking the washer to do it's thing -It acts like the motor is overloaded. Tranmission?: I am afraid this is the culprit...but can this be repaired/reconditioned instead of buying a new one. Are there certain pieces in the guts of the transmission that are the likely culprit? If I must get a new transmission, I may as well just punt and buy a new machine. Thank you very much for the help...I just don't want to spend money on spare parts and several hours trying fix it if it is a lost cause. Ads By Google Related Models |
I have now been able to get the washer to drain and spin occassionally if I help it to get started....(Holding down the lid switch with a screwdriver). Or, if I switch very rapidly from agitation to spin --- this give it the momentum that it needs to get started.... There is often a very loud buzz coming from the motor as it tries to get going. If it buzzes more than a few seconds it will shut off the motor.
This has ruled out the lid switch and drain pump. It still makes a clunky rattle when in agitation. Thanks again ---- I hope someone can help. I really can't afford a new washer right now. |
| Display Modes | |
| Kenmore 70 series washer wont agitate, spin, or drain | xiuzhiwu | Washer Repair | 1 | 07-18-2010 12:59 PM |
| washer kenmore 80 series top loader fills with water wont drain agitate or spin out | dwills | Washer Repair | 0 | 05-27-2010 09:24 PM |
| Kenmore 70 Series sometimes won't drain or spin | PamMortensen | Washer Repair | 1 | 02-11-2010 06:47 PM |
| kenmore 80 series wont spin | spacecase | Washer Repair | 1 | 03-09-2009 03:41 PM |
| kenmore washer 70 series wont spin and drain water | foster13019 | Washer Repair | 1 | 12-20-2008 01:05 PM |
