my washer filled half way up with water then stopped working. humming noise coming from the water valve. wouldthe valve going bad shut the whole washing machine down?
Originally Posted by: dannyc my washer filled half way up with water then stopped working. humming noise coming from the water valve. wouldthe valve going bad shut the whole washing machine down? Danny, No, A bad fill valve should not shut the machine completely down, Only the fill and wash cycle , the unit should still drain and spin. Unless we've got something else wrong. Did you put the dial in the final drain/spin cycle and see what happened ? Also , if you need more assistance, please get us a model number off the machine. :) :) :)
:cool: the humming noise was coming from the motor so i took the pump off and found there was a small sock that had been sucked into the pump not allowing the motor to ingage. luckily this was a quick and inexpensive fix. Thanks
Originally Posted by: dannyc :cool: the humming noise was coming from the motor so i took the pump off and found there was a small sock that had been sucked into the pump not allowing the motor to ingage. luckily this was a quick and inexpensive fix. Thanks Great, Watch out for the socks and other small articles, and the overloading, Thanks for the update. Good Luck, :cool: :cool: :cool:
