DREW255
#1 Posted : Wednesday, October 1, 2008 1:34:03 PM(UTC)
DREW255
approx 2 weeks ago I wrote in about my washer not draining well, and I was told to check the pump and that I could get to it by removing the front panel, How do I do that,I'm a gas service tech, so I work on dryers etc. do I have to take the top off first(like a dryer). thanks
libertyappl
#2 Posted : Wednesday, October 1, 2008 1:46:51 PM(UTC)
libertyappl
Near the bottom of the front panel there are 2 screws to remove the front panel. You don't have to remove the top. Here is the the breakdown on your machine, Model MAH5500BWW
Nat
DREW255
#3 Posted : Wednesday, October 1, 2008 1:58:06 PM(UTC)
DREW255
I just checked for the screws, all I can find at the bottom is what appears to be clips or hinges
libertyappl
#4 Posted : Wednesday, October 1, 2008 2:09:50 PM(UTC)
libertyappl
Sorry, wasn't looking at the model itself.
There are screws around to opening where your clothes go in. Then you can release the clips and the wiring, I'm going from memory here.....I have a set of these in the back of the shop somewhere!
You can see a bit of it from the breakdwon I posted earlier.
Natalie
DREW255
#5 Posted : Wednesday, October 1, 2008 4:19:18 PM(UTC)
DREW255
thankyou for youhelp, I got the cover off, checked the pump for obstructions but found nothing, any ideas as to what is causeing it to not drain and not rinse well?
libertyappl
#6 Posted : Wednesday, October 1, 2008 7:06:51 PM(UTC)
libertyappl
The pump itself may need replacing.
Maytag MED7500YW 1 Front Panel Removal? (Dryer Repair)
by Senator 5/18/2015 4:58:46 PM(UTC)
GE Dryer front panel removal (Dryer Repair)
by Hyperventilate 11/5/2013 8:28:03 PM(UTC)
Full Front Panel Removal (Dryer Repair)
by Inquirer 2/19/2013 1:50:02 PM(UTC)
Front Panel Removal? (Dishwasher Repair)
by jim@vacuumtubesinc.com 8/8/2012 7:33:16 PM(UTC)
LG Dryer front panel removal (Dryer Repair)
by gusnich 4/13/2012 11:16:05 AM(UTC)
Front panel removal (Washer Repair)
by Dean2L2@AOL.com 10/14/2011 12:28:37 PM(UTC)
Front Panel Removal (Dishwasher Repair)
by Edward Wieczorek 7/30/2011 6:40:42 AM(UTC)
GE front panel removal (Washer Repair)
by blevdog 5/18/2011 9:45:16 AM(UTC)
by bobets2@tds.net 11/17/2010 12:13:48 PM(UTC)
by bobets2@tds.net 11/17/2010 12:05:35 PM(UTC)
by skullz 9/12/2009 7:54:07 AM(UTC)
washer front panel removal (Washer Repair)
by zamboy 5/5/2009 3:47:30 PM(UTC)
by Barbara Taylor 3/23/2009 8:39:14 AM(UTC)
Maytag Dryer front panel removal (Dryer Repair)
by jkbatt 8/23/2007 5:49:51 AM(UTC)
