:( AS SOON AS I TURN THE WASHER ON, AND PUSH START, THE DOOR LOCKS AND THEN BEGINS TO MAKE A LOUD RADDLE-HUMMING NOISE AND WILL NOT DISPENCE THE DETERGENT OR BEGIN TO DISPENCE WATER INTO THE MACHINE. HELP! THIS HAPPEND ONCE BEFORE AND I WAS TOLD TO UNPLUG IT.... AND THEN PLUG IT BACK IN! THIS WOULD RE-SET IT, BUT I DON'T REMEMBER THE DETAILS!:confused: PLEASE HELP ME! LAUNDRY IS PILLING UP!:eek:
Originally Posted by: AMY101 :( AS SOON AS I TURN THE WASHER ON, AND PUSH START, THE DOOR LOCKS AND THEN BEGINS TO MAKE A LOUD RADDLE-HUMMING NOISE AND WILL NOT DISPENCE THE DETERGENT OR BEGIN TO DISPENCE WATER INTO THE MACHINE. HELP! THIS HAPPEND ONCE BEFORE AND I WAS TOLD TO UNPLUG IT.... AND THEN PLUG IT BACK IN! THIS WOULD RE-SET IT, BUT I DON'T REMEMBER THE DETAILS!:confused: PLEASE HELP ME! LAUNDRY IS PILLING UP!:eek: Amy, If you're sure both faucets are open and have water to the fill valve,(disconnect the hoses at the faucet or washer fill valve and see if water is flowing, make sure the hoses are not Kinked behind the machine) If there's water to the machine, then based on your description, You'd have to suspect a bad fill valve. Part number: AP3866046
Good Luck, :) :) :)
:d Wow! Your Not Going To Belive This.... Not Saying Anyone Should Do This... But This Is What I Did! I Removed The Detergent/softner Tray And At The Back Is A Plastic Valve Where The Water Comes In At That Looked Like It Needed To Be Wiggled (lack Of Better Words) Lol And Then I Started The Washer Again And It Began Working Properly! Imagine That! I Have A Whirlpool Duet Front-load Washer.... I Don't Know That They Are All Made The Same, But This Is What I Did And It Is Back To The Piles Of Laundry.... Yipee!
Originally Posted by: AMY101 :d Wow! Your Not Going To Belive This.... Not Saying Anyone Should Do This... But This Is What I Did! I Removed The Detergent/softner Tray And At The Back Is A Plastic Valve Where The Water Comes In At That Looked Like It Needed To Be Wiggled (lack Of Better Words) Lol And Then I Started The Washer Again And It Began Working Properly! Imagine That! I Have A Whirlpool Duet Front-load Washer.... I Don't Know That They Are All Made The Same, But This Is What I Did And It Is Back To The Piles Of Laundry.... Yipee! Amy, Glad you're up and running, Hopefully , you'll be OK for a long while. Of course, I can only guess at what may have been wrong, but I think you may have had a stuck diverter nozzle, and you re arranged it back in position when you wiggled it. Good Luck, :) :) :)
