Estate washer will not spin
Estate washer will not spin/agitate on any cycle. It will fill with water, and drains fine on the spin cycle, but will not spin at all. The motor hums as if it is trying to work. Belt looks fine. Drum will spin by hand.
I cannot get you model number to come up, but if this is a Whirlpool made direct drive washer it does not have a belt, so I do not know what you are looking at.
Your symptoms indicate a broken motor coupling, an easy and inexpensive repair. Check out this video. YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!* |
Sorry, the model number should be TAWS750PQ0.
Local repair shop wanted us to try to replace the agitator dogs first, but if that doesn't work, we'll try the motor coupling. Thanks! |
2 Attachment(s)
Quote:
- The motor coupling Part number: AP3963893 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL TAWS750PQ0 Automatic Washer | AppliancePartsPros.com Gene. |
| All times are GMT -7. The time now is 07:45 PM. |
