Discuss
how do you remove the basket from my washer
 in
Washer Repair
how do you remove the basket out of the machine. i took out the agitator tried pulling up on the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » how do you remove the basket from my washer
  #1 (permalink)
Old 09-13-2010, 12:19 PM
Junior Member
tlyons is on a distinguished road
Default how do you remove the basket from my washer
Model Number: lcr7244q2   Brand: Whirlpool   Age: 5 - 10 years
how do you remove the basket out of the machine. i took out the agitator tried pulling up on the basket but wont move. is there a trick or a special tool to use
Ads By Google
Related Models
Maytag LCRE200 Range - F/s Std Ele
Maytag LCRE300 Range - F/s Std Ele
Maytag LCRE305 Range - F/s Std Ele
Maytag LCRE350 Range - F/s Std Ele
Maytag LCRE355 Range - F/s Std Ele
Maytag LCRE383 Range - F/s Std Ele
Maytag LCRE400 Range - F/s Std Ele
Maytag LCRE600 Range - F/s Std Ele
Maytag LCRE650 Range - F/s Std Ele
Maytag LCRE655 Range - S/c F/s Ele
Maytag LCRE682 Range - S/c F/s Ele
Maytag LCRE683 Range - S/c F/s Ele
Maytag LCRE700 Range - S/c F/s Ele
Maytag LCRE750 Range - S/c F/s Ele
Maytag LCRE775 Range - S/c F/s Ele
Maytag LCRE800 Range - S/c F/s Ele
Maytag LCRE805 Range - S/c F/s Ele
Maytag LCRE883 Range - S/c F/s Ele
Maytag LCRG200 Range - F/s Std Gas
Maytag LCRG300 Range - F/s Std Gas
Maytag LCRG305 Range - F/s Std Gas
Maytag LCRG350 Range - F/s Std Gas
Maytag LCRG355 Range - F/s Std Gas
Maytag LCRG382 Range - F/s Std Gas
Maytag LCRG383 Range - F/s Std Gas
Maytag LCRG400 Range - F/s Std Gas
Maytag LCRG405 Range - F/s Cont Clean Gas
Maytag LCRG500 Range - F/s Std Gas
Maytag LCRG501 Range - F/s Std Gas
Maytag LCRG502 Range - F/s Std Gas
Maytag LCRG505 Range - F/s Std Gas
Maytag LCRG560 Range - F/s Std Gas
Maytag LCRG583 Range - F/s Cont Clean Gas
Maytag LCRG600 Range - F/s Std Gas
Maytag LCRG601 Range - F/s Std Gas
Maytag LCRG602 Range - F/s Cont Clean Gas
Maytag LCRG700 Range - S/c F/s Gas
Maytag LCRG705 Range - S/c F/s Gas
Maytag LCRG750 Range - S/c F/s Gas
Maytag LCRG755 Range - S/c F/s Gas
Maytag LCRG760 Range - S/c F/s Gas
Maytag LCRG760A Range - S/c F/s Gas
Maytag LCRG783 Range - S/c F/s Gas
Maytag LCRG800 Range - S/c F/s Gas
Maytag LCRG805 Range - S/c F/s Gas
Maytag LCRG860 Range - S/c F/s Gas
Maytag LCRG860A Range - S/c F/s Gas
Maytag LCRP200 Range - F/s Std Gas
Maytag LCRP205 Range - F/s Std Gas
Maytag LCRP300 Range - F/s Std Gas
Maytag LCRP382 Range - F/s Std Gas
Maytag LCSE400 Surface Unit - Ele
Maytag LCSE600 Surface Unit - Ele
Maytag LCSE601 Surface Unit - Ele
Maytag LCSG500 Surface Unit - Gas
Maytag LCSG501 Surface Unit - Gas
Maytag LCSG560 Surface Unit - Gas
Maytag LCSG600 Surface Unit - Gas
Amana LCU-514 Range - S/c S/i Ddraft Gas
Amana LCU-514D Range - S/c S/i Ddraft Gas
Amana LCU-514E Range - S/c S/i Ddraft Gas
Amana LCU-516D Range - S/c S/i Ddraft Gas
Amana LD10 Commercial Microwaves
Amana LD10D Commercial Microwaves
Amana LD10D2  Commercial Microwaves
Amana LD10MP  Commercial Microwaves
Amana LD10MPS  Commercial Microwaves
Amana LD510 Commercial Microwaves
Amana LD510D  Commercial Microwaves
Amana LD510M Commercial Microwaves
Amana LD510P  Commercial Microwaves
Amana LD510S Commercial Microwaves
Gaggenau LD816-610
Gaggenau LD816-620
Whirlpool LDA3000W0
Whirlpool LDA3000W1
Whirlpool LDA3000W2
Whirlpool LDA3000W3
Whirlpool LDA3005W0
Whirlpool LDA3005W1
Whirlpool LDA3005W2
Whirlpool LDA3005W3
Whirlpool LDA3800W0
Whirlpool LDA3805W0
Whirlpool LDA4000W0
Whirlpool LDA4000W1
Whirlpool LDA4000W2
Whirlpool LDA4000W3
Whirlpool LDA4005W0
Whirlpool LDA4005W1
Whirlpool LDA4005W2
Whirlpool LDA4005W3
Whirlpool LDA5300W0
Whirlpool LDA5300W1
Whirlpool LDA5300W2
Whirlpool LDA5300W3
Whirlpool LDA5380W0
Whirlpool LDA5380W1
Whirlpool LDA5380W2
Whirlpool LDA5380W3
Whirlpool LDA5500W0
Whirlpool LDA5500W1
Whirlpool LDA5500W2
Whirlpool LDA5500W3
Whirlpool LDA5505W0
Whirlpool LDA5505W1
Whirlpool LDA5505W2
Whirlpool LDA5505W3
Whirlpool LDA5520W1
Whirlpool LDA5520W2
Whirlpool LDA5520W3
Whirlpool LDA5525W1
Whirlpool LDA5525W2
Whirlpool LDA5525W3
Whirlpool LDA5600W1
Whirlpool LDA5600W2
Whirlpool LDA5600W3
Whirlpool LDA5605W1
Whirlpool LDA5605W2
Whirlpool LDA5605W3
  #2 (permalink)
Old 09-13-2010, 01:01 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
I presume,
You've also removed the tub cover and top of the unit ?
If you have removed the complete agitator, you should be looking at the drive hub, and on the hub assembly there is a bolt(1) just off center that you need to loosen(do not remove). it may be tough but you should be able to break it loose, and lift the spin tub out.
*** See Below, from service manual ***
1. Remove the agitator.
2. Remove the top assembly.
3. Unsnap eight snap clips holding the tub ring to the tub and set the tub ring aside.
4. Loosen the drive hub screw by four or five turns.
DO NOT REMOVE THIS SCREW.
5. Tap on the head of the drive hub screw to loosen the saddle block.
6. Pull up on the basket and remove it from the tub.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-14-2010, 04:13 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
First off, you need to purchase the special spanner wrench (AP3538707). Without it, you will never get the drive block nut back on really tight to prevent spin tube/drive block failure which is costly and labor intensive.
I routinely back off the drive block nut just a few turns, lift up on the spin basket and pound down on the drive block nut till the basket is free.
You can go to my sticky above "replacing direct drive washer brake shoes" for further info on this.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer loose basket? hawaan Washer Repair 3 09-22-2009 04:52 AM
Washer basket wobbles JamesF Washer Repair 5 01-05-2008 01:43 PM
How to remove basket lbrock Washer Repair 1 10-02-2007 03:04 AM
How to remove spin basket nut richappy Washer Repair 0 10-01-2007 04:19 AM
Can't remove spin basket stgbruced Washer Repair 1 08-19-2007 05:04 AM
