Discuss
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill)
 in
Washer Repair
Washer will fill but will not agitate, spin or drain. Washer makes noise when trying to spin as if a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill)
  #1 (permalink)
Old 09-28-2008, 01:09 PM
Junior Member
cowboys#1 is on a distinguished road
Default Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill)
Model Number: 110.26912691   Brand: Kenmore   Age: 5 - 10 years
Washer will fill but will not agitate, spin or drain. Washer makes noise when trying to spin as if a problem with the gears.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-28-2008, 05:26 PM
Senior Expert
APP Volunteer
iamigor5@yahoo.com is on a distinguished road
Default
try putting in spin ...forget about the noise ..is it draining the water? if its draining its probably the coupler,if its not draining,it could be something in the pump. let us know if you need further help
  #3 (permalink)
Old 09-28-2008, 06:44 PM
Junior Member
Default It will not drain.
Tried and it will not drain.
  #4 (permalink)
Old 01-30-2009, 04:00 PM
Junior Member
ralphs2 is on a distinguished road
Default
will not spin
  #5 (permalink)
Old 01-31-2009, 10:05 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Probably a bad motor.
  #6 (permalink)
Old 03-04-2009, 08:05 PM
Junior Member
mharv is on a distinguished road
Default
This sounds exactly like what has happened to my Kenmore 80 series, and I replaced the pump, tub fills, still won't agitate, spin or drain. And makes a clacking noise in all cycles when you turn it on. I pulled it apart again, and the coupler is broken. So I'm going to try to replace it tomorrow. Hopefully that will do the trick because I have laundry backed up to my den.
  #7 (permalink)
Old 03-05-2009, 02:19 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Does the motor make a loud hum, then click off? If so. remove the outer cabinet and pull the motor out, short the lid switch and see if the motor will run.
__________________
  #8 (permalink)
Old 03-05-2009, 04:26 PM
Junior Member
Default
Fingers crossed, it wasn't the motor. I just finished replacing the couplling and the washer works. I'm washing a load as I type this (20 more to go).
  #9 (permalink)
Old 01-13-2011, 10:13 AM
Junior Member
shawman506 is on a distinguished road
Default Kenmore washer
Had the same problem with my 80 Series Heavy Duty. Problem was the coupler $20 fix. Fixed it from the bottom of washer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate corndogg Washer Repair 129 02-02-2015 06:28 AM
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill but won't spin or agitate iowaguy Washer Repair 1 09-21-2009 10:32 AM
Kenmore Washer will fill/drain,but not agitate/spin help! Washer Repair 1 02-02-2009 06:43 PM
