I just moved in a house and washer is a problem
it is a GE model WWSE5200B1WW top loader
i have read some issues very similar but one thing different i have not read. it washes and does all well then when it gets to spin it clunks or clicks, whatever you want to call it, and it stutters sorta. start stop, start stop and so on for 30 seconds then stops and does it again and does not get clothes dry. but the different thing is that i did the diagnostic test where you turn it to 90 degrees, then hold start and turn it 180 degrees, and go through to checks manually. no errors detected, but when i get to spin, it spins perfectly. then i try it on a regular cycle and it is horrible again. lights dim in rooms when it gets loud an everything. any help is welcome, thank you.
