Discuss
Outer Tub Seal Leak
 in
Washer Repair
IRich Morgan: I have a vintage 1984 Maytag A500 washer. The outer tub has developed a leak around the steel
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Outer Tub Seal Leak
  #1 (permalink)
Old 09-09-2010, 01:01 PM
Junior Member
edatlarge is on a distinguished road
Default Outer Tub Seal Leak
Model Number: A500   Brand: Maytag   Age: More than 10 years
IRich Morgan: I have a vintage 1984 Maytag A500 washer. The outer tub has developed a leak around the steel band that holds the top 1/3 to the bottom 2/3's. Is there a replaceable gasket that is under the band?
Related Models
Maytag A500 WASHER-TOP LOADING
Maytag A5000 WASHER-TOP LOADING
Maytag A500S WASHER-TOP LOADING
Jenn-Air A501 MISC / ACCESSORY
Jenn-Air A501BT MISC / ACCESSORY
Jenn-Air A501S MISC / ACCESSORY
Jenn-Air A501WT MISC / ACCESSORY
Maytag A502 WASHER-TOP LOADING
Maytag A502S WASHER-TOP LOADING
Maytag A503 WASHER-TOP LOADING
Maytag A506 WASHER-TOP LOADING
Jenn-Air A507 MISC / ACCESSORY
Jenn-Air A507B MISC / ACCESSORY
Jenn-Air A507W MISC / ACCESSORY
Jenn-Air A509 MISC / ACCESSORY
Jenn-Air A509S MISC / ACCESSORY
Maytag A510 WASHER-TOP LOADING
Maytag A510S WASHER-TOP LOADING
Maytag A511 WASHER-TOP LOADING
Maytag A511S WASHER-TOP LOADING
Maytag A512 WASHER-TOP LOADING
Maytag A512S WASHER-TOP LOADING
Jenn-Air A516 MISC / ACCESSORY
Jenn-Air A518S MISC / ACCESSORY
Jenn-Air A519 MISC / ACCESSORY
Jenn-Air A519W MISC / ACCESSORY
Jenn-Air A521B MISC / ACCESSORY
Jenn-Air A521W MISC / ACCESSORY
Jenn-Air A526 MISC / ACCESSORY
Jenn-Air A526W MISC / ACCESSORY
Jenn-Air A527B MISC / ACCESSORY
Jenn-Air A530 MISC / ACCESSORY
Jenn-Air A530W MISC / ACCESSORY
Admiral A54F-5TKXW-R WALLOVEN- S/C GAS
Admiral A54F-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FK-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FN-5TKVW-R WALLOVEN- S/C GAS
Admiral A54FN-5TKVWM-R WALLOVEN- S/C MWAVE GAS
Admiral A5651XRS RANGE- D/I CONT CLEAN ELE
Admiral A5892XRS RANGE- S/C D/I ELE
Admiral A5898VRV RANGE- S/C D/I ELE
Admiral A5898XRB RANGE- S/C D/I ELE
Admiral A59-5EXW-R WALLOVEN- S/C ELE
Maytag A590 WASHER-TOP LOADING
Maytag A5910 WASHER-TOP LOADING
Admiral A59E-5EXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59FN-5TVW-R WALLOVEN- S/C ELE
Admiral A59FN-5TVWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59G-5TXW-R RANGE- F/S STD ELE
Admiral A59GN-5TVW-R RANGE- F/S STD ELE
Frigidaire A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag A606 WASHER-TOP LOADING
Maytag A606S WASHER-TOP LOADING
Maytag A608 WASHER-TOP LOADING
Maytag A608S WASHER-TOP LOADING
Maytag A610 WASHER-TOP LOADING
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
  #2 (permalink)
Old 09-09-2010, 01:24 PM
Senior Member
applianceman is on a distinguished road
Default
There is a rubber gasket there that you can replace. However if you haven’t removed the gasket or loosened the clamp you will most likely find that the tub is rusted out right at the seal. If you have taken the gasket off or loosened it try rubbing it with Vaseline and reinstall it. The gaskets give very little trouble unless you remove it, in which case you may have to replace it. Clothes Washer Repair Guide
  #3 (permalink)
Old 09-09-2010, 05:12 PM
Junior Member
Default
Thanks for your speedy expert reply.... I have not yet disturbed the seal... so that was why I asked. I knew once I would open it up I would have to have a plan. A leak can only get worse. It sounds like rust may be the final downfall. I may see if I can get a gasket standing by when I do if the rust hasn't already killed it!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
leak under outer tub jdog Washer Repair 7 11-11-2009 04:31 AM
leak under outer tub jdog Dishwasher Repair 0 10-22-2009 04:14 PM
Kenmore [Frigidaire] Leaking from outer tub seal swanny Washer Repair 2 02-10-2009 06:12 PM
Is seal in outer tub replaceble? rproefrock Washer Repair 1 12-17-2008 04:28 PM
Change tub inner and Outer Water leak jolu172003 Washer Repair 0 01-12-2008 03:23 PM
