Discuss
Crosley washes but only tries to spin.
 in
Washer Repair
My Crosley washer will not spin in the spin cycle it starts to spin but then stops and just agitates.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Crosley washes but only tries to spin.
  #1 (permalink)
Old 09-22-2007, 04:35 PM
Ghite Ghite is offline
Junior Member
Ghite is on a distinguished road
Cool Crosley washes but only tries to spin.
Model Number: CW5000W   Brand: Crosley   Age: 5 - 10 years
My Crosley washer will not spin in the spin cycle it starts to spin but then stops and just agitates. The lid switch is working because the motor starts in the spin cycle and runs and the tub tries to turn slowly sometimes. It appears to be mechanical problem. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-22-2007, 05:45 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You probably have a bad thrust bearing washer. Will need to install a thrust bearing kit with pulley. Pull front panel off and turn tranny pulley in spin direction, opposite from agitate. If no spin, this confirms bad thrust bearing washer. Go to Appliance repairs, Appliancehelp, Appliances, repairs to dryers washers dishwashers fridges repairs microwaves ge maytag kenmore frigidaire westinghouse inglis, appliance how to take apart information, purchasing an appliance help, model number help, for directions, this is basically a Maytag washer so follow directions for a Maytag.
__________________
  #3 (permalink)
Old 09-22-2007, 10:13 PM
Junior Member
Default
Thanks It sounds like that is the problem. I appreciate the information.
  #4 (permalink)
Old 09-23-2007, 03:22 AM
Senior Expert
APP Volunteer
Default
The thrust assembly, when turned, pushes up a cam on the tranny pulley that releases the brake. If washers wear, the brake does'nt get released.
__________________
  #5 (permalink)
Senior Expert
APP Volunteer
Default
The thrust assembly, when turned, pushes up a cam on the tranny spindle that releases the brake. If washers wear, the brake does'nt get released.
__________________
  #6 (permalink)
Old 08-16-2008, 09:35 AM
dinki123 dinki123 is offline
Junior Member
dinki123 is on a distinguished road
Default
i replace with new kit ; how do you adjust. instruction not clear. is there a speacial tool to put clip back on easier. the shaft does not seem to stick out for enoug
  #7 (permalink)
Old 08-17-2008, 05:16 AM
Senior Expert
APP Volunteer
Default
Wrap a towel around a piece of wood and stick it on top of the agitator, then force down the agitator by closing the lid and putting a toolbox on top.
This should help: Also, pry the shaft down with a flat bladed screwdriver to allow insertion of the C clip.
__________________
  #8 (permalink)
Old 08-17-2008, 08:22 AM
Junior Member
Red face crosley model cw6500w
when reinstall the thrust bearing : the is a plactic peice that goes on after the metal bearing. the pic show the ears pointing toward the agitatotor. is this corect. i put mine with the ears pointing toward the pulley. i was not the one who originally took apart so im not sure which way it came out thanks.
  #9 (permalink)
Old 08-17-2008, 10:22 AM
Senior Expert
APP Volunteer
Default
The breakdown picture is usually right.
__________________
  #10 (permalink)
Old 08-17-2008, 11:15 AM
Junior Member
Default
Ok Ill Try That Thank You Sooo Much
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
crosley shelvador fridge not freezing or cooling hear clicking noise noddef2000 Refrigerator & Freezer Repair 3 08-27-2007 09:11 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
