Discuss
washing machine won't drain/spin water out
 in
Washer Repair
My Kenmore washer will go through the wash cycle but will not drain/spin out the water. There is no sound
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washing machine won't drain/spin water out
  #1 (permalink)
Old 09-07-2010, 01:02 PM
Junior Member
roseblock is on a distinguished road
Cool washing machine won't drain/spin water out
Model Number: 110.23812100   Brand: Kenmore   Age: 5 - 10 years
My Kenmore washer will go through the wash cycle but will not drain/spin out the water. There is no sound from the motor during this drain cycle. I've tried different cycles (i.e. permanent press, ultra clean..) and it does not spin or drain on any cycle. I have not had a problem with this in the past. Do you have any idea what the problem might be? Any help would be appreciated!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-07-2010, 04:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad lid switch. Check if it does click when you close the lid. If it does not, the switch is the culprit.
- The lid switch Part number: AP3100001
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-07-2010, 05:12 PM
Junior Member
Default washer won't drain/spin
Hi Gene,
Thanks for the speedy response. I will pick up one today and try to install it by the weekend. Is this a tough task? Wish me luck and thanks again for your help. By the way, I do not hear a click when the lid is closed.
  #4 (permalink)
Old 09-07-2010, 05:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This job is not too difficult for a DIY person. You have to open the control panel and remove the washer cabinet. Good luck and keep us posted.
__________________
  #5 (permalink)
Old 09-08-2010, 07:36 AM
Junior Member
Melinda1973 is on a distinguished road
Default
I posted almost the same question yesterday and got no response, I am glad you did. I just ordered a new pump and will attempt to replace that. My washer always stops when I open the lid, which is why I am trying the pump first.
  #6 (permalink)
Old 09-08-2010, 03:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Melinda,
Your washer is very different. Your question is answered here: Washing machine stopped in midcycle
__________________
  #7 (permalink)
Old 09-09-2010, 07:24 AM
Junior Member
Default
Hi Gene,
This is a beautiful day! I got my washer FIXED this morning. It was the lid switch and my husband and I had it replaced in about 20 minutes. It took a little longer because I cleaned all the residue off the inside and scrubbed down the outside. It looks and runs like NEW! I enjoy a challenge and I'm glad I took the plunge. It saved me over $100. Thank you so much for your help. You are a jewel!!
By the way, I noticed rust on the right side of the tub mount. I'm wondering if it has anything to do with the bleach dispenser being on that side. Can I put anything on the rusty area to prevent further rusting? Have a blessed day.
  #8 (permalink)
Old 09-09-2010, 10:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad you were able to fix it.
Regarding the rust - I believe a sandpaper and some paint can help.
__________________
  #9 (permalink)
Old 10-06-2010, 09:20 PM
Junior Member
She-ra is on a distinguished road
Thumbs up Thanks for saving me $$$
I just wanted to thank you for this wonderful information. I have a Kenmore 110.23812100 purchased in 2002. This weekend it stopped working. It would wash but would not drain or spin. I went in panic mode OMG have to buy a new machine...or pay I'm sure around $100.00 for a 20 min repair. After going to the Consumer Report web site to chekout machines I decided to Google "110.23812100 won't drain or spin". It found several sites including this forum. I decided to DIY and bought the lid switch. Amazon.com had it for $12.95 + 4.99 Shipping. A lot less than Sears. Worse case if it doesn't resolve the issue a whopping $17.94....ordered online Monday, delivered by Wednesday. It took me about an hour and a 1/2. I'm sure much longer than an expert...but what they hey (I'm a female and there were no instructions) I was so proud of myself when I plugged the washer back in , turned the knob and heard that wonderful sound of draining and spinning. This forum is wonderful!
  #10 (permalink)
Old 08-06-2011, 10:47 AM
Junior Member
ssussan is on a distinguished road
Default Thank You
I love the internet. I put the question in my browser and this website pops up with the correct answer. I ordered the $10 part on amazon and pulled up a great instructional video on youtube.
$10 and one hour later, this completely inexperienced person, who has never taken apart an appliance, is now doing a load of laundry.
Thanks for the great advise and saving me money!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine will wash drain but not spin Frank K Washer Repair 3 09-30-2009 07:03 AM
Washing machine will not spin drain tbarry Washer Repair 1 09-06-2009 06:14 PM
washing machine wont spin or drain williemc Dishwasher Repair 1 06-14-2009 05:47 PM
washing machine won't spin the water out it jgosch Washer Repair 1 05-10-2009 09:01 AM
washing machine wont agitate, spin, or drain. rathresidence Washer Repair 1 05-01-2008 04:32 PM
