front load washer is just over a year old and out of warranty. It was in spin cycle and just shut down. No read out on display, nothing. Unplugged and plugged back in but no response. Power is at outlet. This washer gave problem about 7 months ago and they replaced the main control board but I can't remember what the problem was. I removed the front panel but did not see any fuses on the board. Not sure where to go from here without a manual or advise. This is for an animal shelter that I volunteer with and they use it every day. Any ideas??
