Discuss
washer will not spin getting error 58 [E59]
 in
Washer Repair
Hello all- So I have a front loading washer machine that will not spin all, when powered on, it will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer will not spin getting error 58 [E59]
  #1 (permalink)
Old 09-04-2010, 02:03 PM
Junior Member
caleygoff is on a distinguished road
Default washer will not spin getting error 58 [E59]
Model Number: GLTF2940FS0   Brand: Frigidaire   Age: 5 - 10 years
Hello all-
So I have a front loading washer machine that will not spin all, when powered on, it will fill up with water, drain, but will not spin, just hum. I called the repair guy, real nice, asked if I was handy, advised for me tilt the machine on its back and look up. If you see the belt hanging there, its the belt usually.
Well doing this, I did not see any belts hanging, but I did find a tech data sheet for the machine, typed on the inside.
I discovered the machine has its on diagnostic mode in it that will tell you what could be going on with the machine. I did this and the read out says E59 No tacho signal for 3 seconds.
In the manual for these errors, it says check the belt, if in good condition remove the belt.
--The belt is in mint condition
Now the belt is removed see if the electric pulley spins freely, in both directions. If it does, check to see if the resistance in the motor is normal.
---- The pulley spins freely in both directions.
If the motor pulley spins freely in both directions, test the resistance measured in Ohms across the PINs on the motor.
--The resistance on the moter between PIN 4 and PIN 5 is at 117.6 Ohms, and the resistance between PIN 1 and PIN 2, PIN 1 and 3, and PIN 2 and 3, are about 4-5. According the manual the motor is good.
With the belt removed check to see if the drum will spin in both directions.
-- The drum does not spin in any direction, it will kind of turn in both directions, but feels like it stuck or jammed. Visual inspection on baffles on the back side of the drum, show a oil drip trail from the center of the back of the drum. The same point where the main pulley in the brain train connects to the back of the drum. Good dark oil is dripping straight down from here.
With the machine powered on, and the back w/ the belt both off. The machine WILL fill the up, and WILL suck the water out of the drum. The motor WILL spin in both directions, like normal.
I am left to believe that the problem lays with the drum bearings. This is because the motor is working, but the drum still seems 'stuck'.
If this is true, will these parts fix it?
I think it might a little expensive from this site:
Rear outer tub assembly (shell) Part #: AP2578105 Price : $197.55
Part Details - FRIGIDAIRE Rear outer tub assembly (shell), part number: AP2578105.
I found another at Bellparts:
Drum Assy,spin Basket Part #: 134360910 Price : $175.49
FRIGIDAIRE GLTF2940FS0 (07 - MOTOR/TUB) | Bell Parts Appliance Model Lookup
Thanks in advance for all your words on this issue!
Related Models
Frigidaire GLTF2940FS0 Frigidaire/washer
Frigidaire GLTF2940FS1 WASHER
Frigidaire GLTF2940FS2 WASHER
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Frigidaire GLTR1670FS0 WASHER
Frigidaire GLTR1670FS1 WASHER
General Electric GLWN5050M0WS WASHER
General Electric GLWP2000M0WW WASHER
General Electric GLWP2000M1WW WASHER
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1439FC0 WASHER
Frigidaire GLWS1439FC1 WASHER
Frigidaire GLWS1439FC2 WASHER
Frigidaire GLWS1439FS0 WASHER
Frigidaire GLWS1439FS1 WASHER
Frigidaire GLWS1439FS2 WASHER
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1749FS0 WASHER
Frigidaire GLWS1749FS1 WASHER
Frigidaire GLWS1749FS2 WASHER
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Gaggenau GM104-710
Gaggenau GM104-714
Admiral GM1110PRW RANGE- F/S STD GAS
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
Admiral GM3110MPAW RANGE- F/S STD GAS
Admiral GM3110MXAW RANGE- F/S STD GAS
Admiral GM3110PRAM RANGE- F/S STD GAS
Admiral GM3110PRWM RANGE- F/S STD GAS
Admiral GM31113WAM RANGE- F/S STD GAS
Admiral GM31113WAV RANGE- F/S STD GAS
Admiral GM3111GXAW RANGE- F/S STD GAS
Admiral GM3111SXAW RANGE- F/S STD GAS
Admiral GM31211XAW RANGE- F/S STD GAS
Admiral GM3167WUA RANGE- F/S STD GAS
Admiral GM3167WUV RANGE- F/S STD GAS
Admiral GM3210MXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3216WRWM RANGE-F/S CONT CLEAN GAS
Admiral GM32211XAW RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUWM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUA RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUW RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUWM RANGE-F/S CONT CLEAN GAS
Gaggenau GM335-760
Maytag GM3468XUW-X RANGE- S/C F/S GAS
Admiral GM3510PRW RANGE- F/S STD ELE
Admiral GM3531WUV RANGE- S/C F/S ELE
Admiral GM3531WUW RANGE- S/C F/S ELE
Admiral GM3631XUA RANGE- F/S STD ELE
Admiral GM3631XUW RANGE- F/S STD ELE
Admiral GM3862XUW RANGE- S/C F/S ELE
Admiral GM3868XUA RANGE- S/C F/S ELE
Admiral GM3868XUW RANGE- S/C F/S ELE
Maytag GM4151WTA RANGE- F/S STD GAS
Maytag GM4151WTW RANGE- F/S STD GAS
Maytag GM4251WTA RANGE-F/S CONT CLEAN GAS
Maytag GM4251WTW RANGE-F/S CONT CLEAN GAS
Whirlpool GM8131XEB0 CONVECTION MICROWAVE OVEN
Whirlpool GM8131XEB1 MICROWAVE
Whirlpool GM8131XEQ0 CONVECTION MICROWAVE OVEN
Whirlpool GM8131XEQ1 MICROWAVE
Whirlpool GM8155XJB0 MICROWAVE-COUNTERTOP
Whirlpool GM8155XJB1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJB2 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJQ0 MICROWAVE-COUNTERTOP
Whirlpool GM8155XJQ1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJQ2 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJT0 MICROWAVE
Whirlpool GM8155XJT1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJT2 CONVECTION MICROWAVE OVEN
Gaggenau GM915-710 UC/06 (FD 7710-7912)
Gaggenau GM915-710 UC/11 (FD 7912-8003)
Gaggenau GM915-710 UC/12 (FD 8003-)
Gaggenau GM926-710 UC/06 (FD 7710-7912)
Gaggenau GM926-710 UC/11 (FD 7912-8003)
Gaggenau GM926-710 UC/12 (FD 8003-)
General Electric GMAN1200L2WW WASHER
  #2 (permalink)
Old 09-04-2010, 02:55 PM
Junior Member
Default photos of inside machine
I tried to get a good picture here, but its still grainy. See the darker grey line in the middle of the baffle? That is what I believe to dirty oil/greese.
  #3 (permalink)
Old 09-05-2010, 06:53 AM
Junior Member
Default confirmation?
Can someone confirm if this is whats going on? Could it be the Speed board that would prevent the drum to spin? Should the drum spin freely in both directions?
  #4 (permalink)
Old 09-05-2010, 07:52 AM
Member
David F is on a distinguished road
Default Possible Solution
From my limited experience I would say your seal and bearings have failed.
It appears that you have the inner tub removed from the outer tub (the one you have the photographs of). The only normal other reason for the inner drum being stiff to turn is something caught between the two drums, small items of clothing or things left in pockets.
As far as I am aware there is no reason why the control board would prevent the drum spinning with the belt off, however I am not familiar with this particular machine.
The stain does look like grease and is typical of failed seals and bearings. What happens water gets into the bearing housing and starts to corrode the bearings, the grease already in the housing mixes with this water and when the machine stops this mixture runs down the inside and the outside of the rear ‘half’ of the outer drum.
Should your inner drum and spider be in good order you would only need the rear half of the outer drum, which comes complete with seal and bearings.
Should you be ‘handy’ enough you may be able to get the seal and bearings out yourself and find a local supplier who can match them, perhaps not an exact match but an acceptable substitute, and then fit them, this will save you even more $$$. The only thing is it is not a Frigidaire ‘approved’ repair.
The parts you have listed would appear to be satisfactory and are available at Sears dot Com / Parts direct (no spaces) for the outer tub c/w seal and bearings part # 134509510 for $190.33 and for the drum part # 134360910 $150.99 plus taxes, plus S&H.I believe Sears can be expensive for S&H so you will have to find out what is your best deal.
Good Luck and let us know how it turns out.
  #5 (permalink)
Old 09-05-2010, 04:27 PM
Junior Member
Default A Pair of Panties... go figure.
So you asked for a response. I started the project of dissembling the washer at about 10:30AM this morning, and finished at about 6:15PM. Total work time about 7hours and 45mins.
As I was pulling the drum out of cabinet, I told my mother who was watching I bet its gonna be some underwear of some sort. As I unbolted the back of the outer drum from the front, and lifted it away, I hear a burst of laugher(mind you this is right after I cover the bearing junction with WD-40). I look down and I find a bunched up pair of panties that look like they have seen better days.
Now the washer, is quieter, and runs like a champ, almost new... While having the machine stripped apart, the water pump, seems to have quite a collection in its water trip. I found old milky way bars (how they got there I can't begin to think), many many quarters, pennies, dimes, nickels, (enough to almost buy lunch), hair barrats, and little hair twisties.
I must confess I KNEW nothing about washer machines and how they functioned two days ago. But after disassembling this machine, and putting it back together, I have clear understanding now.
I found a nice step-by-step service manual online, that helped me through the process. That site is here:
http://www.frigidaireservicetips.com...isWasherSM.pdf
Doing it myself AND not buying a $200 part saved me tons of money... lets do the math.
The tech said it would be $45 to come out place $8 a hour, plus parts and tax. Knowing me I would have already bought the part so lets assume I did.
SERVICE CALL: $45.00
PRICE PER HR: $8.00
TOTAL HRS WRKED: 7:45
PARTS: $175.49
TOTAL: $285.49
To some it all up, I think I came out ahead on this one folks!!
Thanks for your time!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune front load 3E error during spin garrowg Washer Repair 34 07-19-2017 08:37 AM
My Whirlpool duet won't spin, No error codes Suznj Washer Repair 0 08-30-2010 09:04 AM
won't spin or drain,no error codes crewchief Washer Repair 0 03-15-2010 11:07 AM
Spin Cycle Stops @ 7 Minutes (no Error Code) jacksouix Washer Repair 4 09-02-2009 06:39 PM
Error Message during spin cycle lorin83 Washer Repair 1 08-24-2009 03:10 PM
