Discuss
Kenmore Washer F1 error code
 in
Washer Repair
I need to find out the part to fix the F1 error code on my washer (Serial # CU 0270602).
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer F1 error code
  #1 (permalink)
Old 09-02-2010, 01:31 PM
Junior Member
RoxieD is on a distinguished road
Default Kenmore Washer F1 error code
Model Number: 110.27082604   Brand: Kenmore   Age: 1 - 5 years
I need to find out the part to fix the F1 error code on my washer (Serial # CU 0270602). Other blogs have suggested a new circuit board, a new machine/motor control assembly or a new electronic control with the part # 26.110 W1018966. The problems: a few seconds after starting, the machine will stop the washer, unlock the lid and flash the F1 error code. So far, I've been able to stop and restart the machine a few times and then it will finish out the cycle just fine. The past day or two, though, I've had to unplug it, wait 15 seconds, and replug it in just to get it to start in the first place, then I have to babysit it through the F1 error code start/restart procedure. We can replace the part ourselves, but we do need to figure out which part(s) to purchase. Thanks so much for your time!!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-02-2010, 02:26 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Roxie,
Check the air dome transducer hose first,
(the clear plastic tube that goes from the control board to the right side of the outer tub connection)
for kinks, clogs, twists,etc.
If the hose is OK,
Yes, you will need to replace the control board.
(Click here)
Part number: AP4360738
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-14-2010, 08:06 AM
Senior Expert
Default
Quote:
Originally Posted by Joe / APP Team View Post
Roxie,
If the hose is OK,
(Click here)
Roxie,
As I understand it,
You replaced the CCU , and checked the airdome hose,
Now, your machine has a fill problem, then you heard a POP and now you have a "LF" code, is that correct ?
You noticed nothing else wrong before contacting the APP Team, other than the "F1" code ?
The "LF" code indicates a long fill cycle,
Are you sure the fill hose(s) weren't kinked , when you moved the machine back into position ?
Are the fill hose and valve screens clogged with debris from the water pipes ?
Is the tub "stuck " on the drive sprocket ?
(you should be able to grasp the spin tub top ring, and lift the tub up 1/2 to 3/4", without any difficulty).
Are you sure none of the wires to the motor or pumps, were dislodged , or loose, when you checked them ?
The air dome hose was not twisted or kinked when the repair was finished ?
If all of the above are OK and check proper,
I reccomend you replace the motor control and harness, we're getting a false / improper input to the CCU.
Part number: AP4327312
You may also want to return the CCU you orderred for a replacement, just in case that "pop" noise was a shorted circuit.
Good Luck,
__________________
Joe M. APP TEAM
  #4 (permalink)
Old 10-06-2010, 03:36 PM
Junior Member
Default LF code
Hi Joe! Thanks for responding to my post. We replaced the control board with the part Appliance Parts Pros.com sent. Now we are getting the LF error code on certain wash cycles. The washer will not fill and I know it's not dispensing liquid fabric softener. When it stops the washer with the LF code, the only thing I can do is turn the machine off, let it drain, then restart it using the rinse/drain cycle. Any suggestions? We never had this problem before with the LF code...could it be a defective control board? I really appreciate the time and effort you're putting toward our problem. Thanks so much!
  #5 (permalink)
Old 10-07-2010, 06:35 AM
Senior Expert
Default
Roxie,
I see you got my previous post,
I don't recall exactly, but you're on the second or third control board, and I don't think another will solve the problem.
That's why I directed you to the air dome hose and bellows,and harness to the motor.
You also need to check the drain pump for debris, calcium and detergent build up inside the pump.
Then, if all checks are good, your next move would be to install the motor control kit, I reccomended in the previous post.
There is a miscommunication between the the CCU(main control board) and the lower components or harness. That's why the manufacturer composed the kit.
I'm pretty sure if you do all the checks and replace the motor control kit, you'll be fine from there on.
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 07-03-2013, 10:30 AM
Junior Member
r henry is on a distinguished road
Default Boiling Water is all you need!
On my Kenmore 110.27032600 washer, I was able to remedy the F1 code very, very simply.
Boil about 4 cups of water. Carefully pour 2 cups of the boiling water into the place where you pour detergent (front left side on mine). Pour the remaining two cups boiling water into the place where you pour bleach (rear left on mine).
F1 error indicates that the tubes that carry detergent/bleach are clogged. The boiling water will unclog the tubes.
  #7 (permalink)
Old 07-03-2013, 11:28 AM
Senior Expert
Default
R Henry, Thanks for your input, it will come in handy for future reference for those that may have a dispenser issue or erratic error codes in their "Cabrio" washer. Like all error codes in most products, they are "indications" of issues and can be as much as 98% accurate. But there's no 100% accuracy.
Thanks Again,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HE3 Washer F02 Error Code sseering Washer Repair 5 02-05-2013 06:13 PM
Kenmore error code F23 fatoleigh Washer Repair 2 06-13-2010 03:54 PM
Kenmore HE3 with F02 Error Code AC_73098 Washer Repair 3 07-15-2009 08:42 AM
Kenmore Washer Error Code allezmont Washer Repair 1 06-06-2009 10:48 AM
Kenmore E0 F2 error code rjdoss Oven Repair (including Ranges and Cooktops) 1 12-07-2008 06:59 AM
