Painin the**
#1 Posted : Wednesday, September 17, 2008 6:44:58 PM(UTC)
Painin the**
ALL cycles work fine on machine except spin, which does spin OK. You get a very violent clunk when it 1st starts into the spin cycle & about every 5-7 seconds after that while the machine is spinning. Tub breaks & starts up fine. Acts almost like is being hit with something when the clunk happens. You can see the agitator jerk for just a second when it happens too. Happens whether clothes in it or not & does not matter what the water level or temp is. Can not seem to see or find any broken, bent or loose parts by visual inspection. Someone please help, any suggestions would be greatly appreciated. :( :confused:
libertyappl
#2 Posted : Wednesday, September 17, 2008 6:49:08 PM(UTC)
libertyappl
Sounds like the balance ring is messed up.
nat
Painin the**
#3 Posted : Wednesday, September 17, 2008 6:52:34 PM(UTC)
Painin the**
Sorry to sound stupid, but a balancer ring is? & how hard would it be to determine if that is the problem. Don't know much about washers.
libertyappl
#4 Posted : Wednesday, September 17, 2008 7:00:32 PM(UTC)
libertyappl
Here's the breakdown of your machine. Model GSQ9364HQ0 Unfortuneatly the balance ring only comes with the basket on your model. It's also possible the it be #19.
I'm still reviewing. If you want I can "talk" you through a few steps to check.
Nat
Painin the**
#5 Posted : Wednesday, September 17, 2008 7:24:59 PM(UTC)
Painin the**
I can not do it right now because got to go towork at 3am & is 10:30here. Would greatly appreciate any help & that would be great. Could you send a check list & could go through it tomorrow night when I get home & just send a message & let know when I get list done. Am a regional truck (semi) & tryin to do this when not at work. All help is GREATLY appreciated. Please let me know
libertyappl
#6 Posted : Wednesday, September 17, 2008 7:27:50 PM(UTC)
libertyappl
That's not a problem. I'm on here a lot through out the day and evenings, except Friday nights, have to go to son's football games and some weekends.
It's 10:30 here too!
Will you need detailed instructions for getting into the machine? I will try to locate the service manual for your machine.
nat
#7 Posted : Thursday, September 18, 2008 1:30:42 AM(UTC)
Pull the agitator out and check the drive block for play. Just try to turn the spin basket back and forth tho check. If bad, you will need a new drive block AP2905773 and the special spanner wrench.
