Discuss
Washer Leaking Black Fluid Thru Holes in Tub
 in
Washer Repair
We have a Maytag washer that is probably 20 years old. It is leaking a black fluid thru the holes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Leaking Black Fluid Thru Holes in Tub
  #1 (permalink)
Old 08-31-2010, 12:58 PM
Junior Member
cjwest is on a distinguished road
Default Washer Leaking Black Fluid Thru Holes in Tub
Brand: Maytag   Age: More than 10 years
We have a Maytag washer that is probably 20 years old. It is leaking a black fluid thru the holes of teh tub. I thought it might be grease but does not feel greasy to teh touch, but leaves black stains on the clothes.
Would it be worth calling a repairman or just buy new?
  #2 (permalink)
Old 08-31-2010, 02:02 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
CJ,
Try this first , then you can decide.
Take an article with a stain on it.
Iron the spot with an iron, or run hot water on the spot, and wring it out.
Smell the spot, The heat will activate the molecules in the stain and produce an odor.
If it smells "sweet" like softner or detergent or other additive(s)it's not an oil leak, just a build up of chemicals and dirt in the tub.
If it smells like motor oil or an old sisal rope, you've got a leak in the transmission and mounting stem/seal.
You're talking major overhaul / repair if that's the case.
If it's a sweet odor, that can be washed out, with hot water and a de greaser or strong detergent.
Good luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Black marks & holes duncans810 Dryer Repair 0 03-07-2010 12:38 PM
leaking valve injector thru the air holes jim devlin Washer Repair 1 02-12-2009 05:21 AM
Whirlpool leaking fluid on floor idobelieve Washer Repair 1 08-15-2008 12:06 PM
