Discuss
Whirlpool makes noise at end of wash cycle
 in
Washer Repair
At the end of the wash cycle there is a loud noise. I have a new coupler to put on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool makes noise at end of wash cycle
  #1 (permalink)
Old 09-21-2007, 04:24 AM
brfiel brfiel is offline
Junior Member
brfiel is on a distinguished road
Default Whirlpool makes noise at end of wash cycle
Model Number: LSR7233DQO   Brand: Whirlpool   Age: More than 10 years
At the end of the wash cycle there is a loud noise. I have a new coupler to put on but the old one was not really worn out. How do I take off the transmission, clutch and brake to see what to replace.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-21-2007, 11:01 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the loud noise is at the end of a spin cycle, you have dragging brake shoes.
If you have an amprobe, you can verify by measuring the motor current during spin.May be as high as 11 amps.
To fix,refer to your model # above for take apart info. and just pull agitator, losten the spin basket nut 1/2 way out and pound on the top of nut till the spin basket breaks loose.
Now pull motor out and turn the tranny coupler clockwise untill the basket starts to spin, if now very hard to turn with one hand, you have dragging brake shoes. Now pull transmission out and pry down the brake shoes, but leave the spin tube in the washer. Now remove the spring,cam and brake shoes and replace them. You can get your shoes by clicking on your model # above.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Makes loud noise when spinning waggie Washer Repair 0 09-03-2007 02:05 PM
Agitator squeeks during wash cycle poskas Washer Repair 0 08-22-2007 10:05 AM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 09:38 AM
After wash cycle will not drain and spin out IndianaPanda Washer Repair 0 08-08-2007 01:15 PM
quick wash cycle vicky Washer Repair 1 07-23-2007 03:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
