the washer when it got to the rinse cycle would not start to fill. guy on u tube said to replace water mix valve. I bought it from you here. Now the washer when set 2 cold water will work fine rinse and all, but when u set it on hot water will not fill on rinse cycle at all now im testing it with cold water out of the water hose that should not matter should it what could be going wrong??? thank you
