Discuss
Delicate or Perma Press Cycles do not work
 in
Washer Repair
My washer works on the normal cycle only. When set to the delicate cycle, the water fills up and when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Delicate or Perma Press Cycles do not work
  #1 (permalink)
Old 09-20-2007, 01:12 PM
tallgirl tallgirl is offline
Junior Member
tallgirl is on a distinguished road
Default Delicate or Perma Press Cycles do not work
Model Number: LSQ9200KQO   Brand: Whirlpool   Age: 5 - 10 years
My washer works on the normal cycle only. When set to the delicate cycle, the water fills up and when it should start to adgitate, it just buzzes, then if you wait a few minutes, it will run the water out. It has not washed the clothes through a normal wash, rinse, and spin cycle. It does this in the perma press cycle also. Would this washer need a timer part?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-21-2007, 03:33 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Normally, I would remove the timer cover and check the contacts, if badly burnt, that's your problem. If not, you may have a bad motor or a bad pin on the connector. If you have a meter, check for voltage to the motor pins per the schematic and push in on all the connector pins, they may have worked loose.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer only works in delicate cycle ric Washer Repair 3 09-16-2007 03:25 AM
stops on heating delay between cycles scoot Dishwasher Repair 1 09-13-2007 03:14 AM
Countdown Display INOP, Washer cycles normally Julia Dishwasher Repair 0 08-20-2007 10:03 PM
Whirlpool washer will not advance cycles GARY H Washer Repair 0 08-14-2007 07:18 PM
Dryer won't shut off on Cotton or Perm Press wlucas001 Dryer Repair 0 08-12-2007 07:26 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
