lg front loader washer, it won't turn on unless i unplug the machine and then plug it back in, it will stay on for about 10 minutes and then no power. I've tried different outlets, does the same thing. This is when its not even being used, as far as running a cycle. Not a breaker issue. it's like it doesn't remember it has power. I emailed lg, they don't have an answer. Quite the mystery, any help would be appreciated.
Thanks, Dale
