my washer leaks after washing a load of clothes, the water is clear so is not coming from spinning out. I cant figure out where it is coming from. Any help would be great and yes I have had the washer apart. thanks
Originally Posted by: khcoop my washer leaks after washing a load of clothes, the water is clear so is not coming from spinning out. I cant figure out where it is coming from. Any help would be great and yes I have had the washer apart. thanks Do you have the model number, so we can assist you better. Did you see any water or water marks inside or on the base of the machine ? Usually, water on the floor after a cycle is done indicates a drain problem, or a loose fill hose connection, and in some cases a leak from the faucet,unless its a splash over or suds from too much detergent. You may want to check and varify those possibilities. Then get us the model number and we can give you a better diagnosis. :) :) :)
