Discuss
Used Frigidaire stackable has weird issues
 in
Washer Repair
Hello All, We purchased a used 27" washer/dryer last night, hooked it all up and it acts very strange. The
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Used Frigidaire stackable has weird issues
  #1 (permalink)
Old 09-10-2008, 08:00 AM
Junior Member
Kanine21 is on a distinguished road
Default Used Frigidaire stackable has weird issues
Model Number: FEZ831AS1   Brand: Frigidaire   Age: 1 - 5 years
Hello All,
The 220V cord was cut when we bought it, so I took the old pigtail off our broken machine and wired it to this one. Our old machine is almost EXACTLY the same, just much older and has many mechanical issues.
What happens with the new machine is the washer will not start unless you have the dryer operating at the same time and press the Start button for the dryer! If the dryer switch is in an off position, the washer will not start at all even if you press the start button for the dryer.
If you want to start the dryer without washer, you can't unless the washer switch is in any mode with the switch pulled out, and the dryer in a mode then hitting the Start button.
When the dryer is on, the light bulb inside doesn't come on when we open the door (burnt bulb I suspect), but if we defeat the door switch and run the dryer to verify operation, the heater coils in the back start getting red hot! Should they get THAT hot? Also the tumbler spins counter clockwise, is that correct?
I opened the acess panel under the control panel to get the Schematic/Tech Data sheet and of course it's missing, somebody must have tried messing with it before and we may have gotten hosed on this unit.
We only got it for $200 and I'd like to fix it for cheap to make it a worth while investment, but is it worth it? Should we demand our money back since it was advertised as working?
Only thing I could think of is when I connected the wire to the terminal block, maybe Line 1 and Line 2 were swapped? Would that make any difference being 220V? I wouldn't think so, unless the phases have something to do with it. The wiring labels are the exact same on each unit and they both show the 220V wiring to the terminal block as being the exact same, so I doubt I have it mixed up, but I'm not 100%, even if I do, would the syptoms be, if any?
Any help is really appreciated!!!
Kane
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 09-10-2008, 08:46 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Sounds like you have a wiring NIGHTMARE with the unit. If you choose to tackle this the wiring diagram is shown on this site although it small it may help. Model FEZ831AS1
The Dryer element does get red hot. The drum is NOT turning in the correct direction!
Out of curiosity what was your old unit doing?
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-10-2008, 09:26 AM
Junior Member
Default
Yeah, I'm thinking somebody replaced a switch or relay or something and reconnected it wrong.
Since the unit is almost identical to the old, I'm going to steal the old schematic and follow the base power wiring grid to make sure the switches are all wiring properly. Sounds like it could either be a nightmare, or maybe a couple harnesses switched.
Thanks for the confirmation of the coils, but why would the tumbler spin backwards on an AC induction motor? Doesn't really make much sense to me.
The old unit has several issues, first was the previous owners did some mickey mouse repair to the agitator spindle top and JB welded it in place cause it stripped out, so in agitation mode with a load in, it barely moves the clothes AT ALL. That plus clothes come out smelling very moldy and musty, there must be a load of builup in the bucket. We tried the white vinegar trick and other cleaners, cleaned the drain hose, inspected all water fittings, etc.... and nothing got rid of the smell.
The dryer also had issues drying even half loads. I cleaned out the blower ducting and the dryer hose going to the wall and it only slightly improved.
Thanks for the tips! Sounds like it's time to break out the trusty Fluke!
Kane
  #4 (permalink)
Old 09-10-2008, 09:37 AM
Senior Expert
APP Volunteer
Default
The drum could trun backward they probably have the motor wired backwards.
As for the older one, check the entire venting system from the lint trap all the way to the outside. There may be an obstruction before it gets to the blower (like a sock, underwear etc.) Post your model number on the old one and I'll check out the agitaor & smell issues a little.
Nat
__________________
  #5 (permalink)
Old 09-10-2008, 10:06 AM
Junior Member
Default
yeah, I'm wondering what the hell they did to this thing.
The old one's agitator isn't really repairable anymore, too many monkeys that didn't know what they were doing screwed up the agitator. The top clamp nut has basically a clutch washer that was stripped/worn. So they decided to JB weld the top part in place to the spindle. The JB weld broke at the spindle, but the top part is impossible to get off now.
I chiseled away at it and could see the threads on the spindle where the pem-nut was pressed into the top cap were all chewed up, thus the reason for the JB I'm guessing. Instead of replacing a $20 cap, they basically ruined the spindle and cap and made it unrepairable unless the whole bucket/agitato is replaced.
I wanted to take the washer apart and dissasemble the bucket and clean it good, but it's damn near impossible to get the side covers off to get to things.
Kane
  #6 (permalink)
Old 09-10-2008, 10:11 AM
Senior Expert
APP Volunteer
Default
Post the model number of your old unit, I think you could fix it for less than the $200 you paid for the other one.
Nat
__________________
  #7 (permalink)
Old 09-10-2008, 10:54 AM
Junior Member
Default
Thanks again, Nat!
I don't have the old units part number on me, but it's 1996 year Kenmore 27" stackable. The whole chassis is EXACTLY like the Frigidaire unit, only exterior difference is the control panel and lack of the smal fluorescent light above the washer lid on the Frigidaire unit.
I probably could spend a ton of time and little money fixing the old unit, but I already spent hours trying to take it apart in our tiny condo and I wasn't too successful except making the dryer work better. I did clean out the whole venting system and relieved it of any clogs for certain, and the blower works perfectly, maybe the coils were getting old and not conduting as well as they could have, thus not getting hot enough.
The agitator wasn't the only issue, but sometimes the spin cycle wouldn't get enough speed to wring out the clothes very well and sometimes the clothes would still be dripping soaking wet after a standard cycle and 3/4 size load. Maybe something to do with the valving? I'm not sure. Could be the reason the dryer wasn't effectively drying the clothes.
I just know that after so much time working on it, I had to give up cause I was fighting a losing battle and we have a laundromat in our complex luckily.
Sure I'll have to spend some time trouble-shooting this new unit, luckily I know wiring fairly well and I hope I can find the problem and hope I don't spend hours upon hours on it.
If anything, I can trace wires in the old unit to compare if the schematic isn't too forthcoming on answers for me, haha.
I'll post the number of the old unit tonight when i get home, but don't worry about spending any of your time on it, it's been pretty well beat up.
If I find the wiring issue tonight, I'll definetly post with the results in case this ever happens to anyone.
Wish me luck!
Kane
  #8 (permalink)
Old 09-10-2008, 11:44 AM
Senior Expert
APP Volunteer
Default
Good luck indeed! I think I would start with wiring to the motor & controls.
Nat
__________________
  #9 (permalink)
Old 09-11-2008, 03:11 PM
Junior Member
Default
Well unfortunatly the old schematic from the old machine has a bit different wiring. Even the motor wiring is different, so i din't have much luck last night.
looking at the old unit, the dryer motor has a plug on it for a harness vs. actual termianls that you could screw up. All the plugs I could find on the new unit look original and untouched, but I'm still convinced somebody got in there and messed with something.
Something has to be in serial that shouldn't be if the dryer start button starts both the dryer and washer. ugh...
Kane
  #10 (permalink)
Old 09-11-2008, 07:27 PM
Senior Expert
APP Volunteer
Default
Were you able to read the wire diagram I posted earlier? If not and yours isn't present you can generally order them too
Nat
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Stackable W/D, leaking tub seal FDAR Washer Repair 6 08-10-2011 07:27 AM
Frigidaire stackable won't spin markpisc Washer Repair 9 11-17-2009 02:00 PM
frigidaire stackable is leaking hdsnoopy75 Washer Repair 1 11-13-2009 05:21 PM
frigidaire stackable washer and dryer afeuquay001 Washer Repair 1 10-19-2009 10:34 AM
Frigidaire stackable dryer - which side of belt karenfromusa Dryer Repair 0 07-22-2009 04:51 PM
