Discuss
Used Frigidaire stackable has weird issues
 in
Washer Repair
The wire colors and component designators weren't clear enough for me. I sat in front of the panel tonight and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Used Frigidaire stackable has weird issues
  #11 (permalink)
Old 09-11-2008, 07:51 PM
Junior Member
Kanine21 is on a distinguished road
Default
I sat in front of the panel tonight and messed around with the connections since there was a TON of dust and lint. Didn't find anything out of place. I decided to place the panel back up with a couple screws and try it out again, and everything seems to work normally!
Not sure what the heck it could be besides maybe the timers or something stuck or just not working properly.
I started the dryer normally and it started fine, same with the washer.
I'm running the washer through a couple cycles and it seems to stop on the final rinse for some reason, telling me the cams might be worn in the washer timer switch, or maybe just dirty contacts.
I'm running it through again and seeing if it'll work itself out, if so I know something is funky with the cams in the timer switch.
Another note is the dryer motor also runs the blower motor, direct shaft, all one unit. So I figured if the dryer tumbler was truely spinning the wrong direction, that the blower would spin backwards, blowing dust out of the ducting INTO the dryer, vs. a vacuum effect. I opened the dryer door and defeated the switch and started the dryer, I put my other hand over the lint trap and it seemed to have a strong vacuum and I didn't see any dust/lint flying out at all, so maybe this unit runs counter clockwise? Weird....
As the unit is running right now, I smell a burning rubber smell, the belt might be worn for the washer, I'll take the front panel off tomorrow and inspect. I've stopped it for now.
I'll post more once I get the rest working normal. As always, thanks again for the tips!
Kane
Ads By Google
  #12 (permalink)
Old 09-11-2008, 07:56 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
You're welcome! it was probably a loose wire. Although I have never seen a dryer drum turn counter clockwise!!!!! Keep a close eye on it. Would definately recommend not leaving the house with it running!!
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #13 (permalink)
Old 09-11-2008, 08:28 PM
Junior Member
Default
Yeah, I've never seen one run CCW either, that's why it caught my eye.
I just felt the blower again and actually it does feel like it's blowing into the dryer, not vacuuming. I'm thinking the burning rubber smell from the washer is the washer motor spinning backwards also, causing the belt to slip since it's rotating opposite of the tensioner tension, makes sense.
I just don't know what's backwards? Why would both motors spin backwards?
Just for shits n' giggles I removed the power wire and switched L1 and L2, of course it made no difference, ugh...
This is really puzzling me!
Kane
  #14 (permalink)
Old 09-11-2008, 09:34 PM
Senior Expert
APP Volunteer
Default
trying to post the wire diagram for you. I think the L2 & neutral are swapt, just a guess.
Nat
__________________
  #15 (permalink)
Old 09-12-2008, 10:22 AM
Junior Member
Default
Quote:
Nat
I can't read that schematic too easy, just too convoluted online. I'm ordering one today.
I'm trying to think where they'd be swapped if they are. I know it's not the power cord, nor the terminal block mains wires, I've confirmed that.
It's got to be a common area, some kind of distribution area that both motors pull their power from.
I'll have time to tear it all apart this week and trace things at least, hopefully I can find something. I'll check the L2 vs. Neutral as you suggested, they both seem to go to the dryer timer. Although L1 goes to both the Dryer timer, and Washer timer.
Kane
  #16 (permalink)
Old 09-12-2008, 10:53 AM
Senior Expert
APP Volunteer
Default
Keep us posted.
Nat
__________________
  #17 (permalink)
Old 09-12-2008, 12:25 PM
Junior Member
Default
Keep us posted.
Nat
Well I found the official schematic in .pdf form here: http://www.frigidaire.com/support/Re...earch=Se arch
Can't believe I didn't even think of looking there. I went over the schematic and it's hard to see why the motors would spin backwards, even if N and L2 or L1 were swapped at the motor, it won't matter since it's 120V singe phase. The windings in the motors determine direction of spin on an AC induction motor. I'm so confused, but at least I have a data sheet to pick things apart with and at least confirm connections.
Kane
  #18 (permalink)
Old 09-12-2008, 12:27 PM
Senior Expert
APP Volunteer
Default
That's the one I tried to post but after it getting shrunk down to the peramitors......well you know the rest.
Nat
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Stackable W/D, leaking tub seal FDAR Washer Repair 6 08-10-2011 07:27 AM
Frigidaire stackable won't spin markpisc Washer Repair 9 11-17-2009 02:00 PM
frigidaire stackable is leaking hdsnoopy75 Washer Repair 1 11-13-2009 05:21 PM
frigidaire stackable washer and dryer afeuquay001 Washer Repair 1 10-19-2009 10:34 AM
Frigidaire stackable dryer - which side of belt karenfromusa Dryer Repair 0 07-22-2009 04:51 PM
