Discuss
Washer won't empty/spin
 in
Washer Repair
The machine just finished a load with the burnt odor, so I opened to look inside. The belt was very
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't empty/spin
  #1 (permalink)
Old 09-19-2007, 07:55 PM
ironglen ironglen is offline
Junior Member
ironglen is on a distinguished road
Default Washer won't empty/spin
Model Number: LW8203L2   Brand: Amana   Age: More than 10 years
The machine just finished a load with the burnt odor, so I opened to look inside. The belt was very loose and cracked, so I replaced with a slightly (1cm less) shorter belt from the auto store. The plastic pump under the motor had an oily film on it (?lost lubricant) and the 'impeller' seemed loose inside. Upon reassembly, washer filled, then smoked (motor) a couple tries at the switch, and quit.
First off, if the motor is burnt (there was odor and the front panel has smoke marks), is it worthwhile to replace it for ~$170? Correct me if I'm wrong, but a new water pump ~$50 would seem like a good idea as well with the 12 yr old age of the unit. Will other parts need replacement as well that should lead me to buy a new machine? There appear to be very few mechanical parts, however, a look at other posts seem to convince me that there may be seals, transmission, and main bearing that will fail (eventually). On the other hand, the machine has a stainless basket and appears well made.
Any ideas, suggestions welcome.
Thanks.
Glen
Related Models
Amana LW8203L2 Washer - Top Loading
Amana LW8203W Washer - Top Loading
Amana LW8203W2 Washer - Top Loading
Amana LW8203W2B Washer - Top Loading
Amana LW8252L2 Washer - Top Loading
Amana LW8252W2 Washer - Top Loading
Amana LW8253W Washer - Top Loading
Amana LW8263W2 Washer - Top Loading
Amana LW8303L2 Washer - Top Loading
Amana LW8303W2 Washer - Top Loading
Amana LW8312L2 Washer - Top Loading
Amana LW8312W2 Washer - Top Loading
Amana LW8363L2 Washer - Top Loading
Amana LW8363W2 Washer - Top Loading
Amana LW8403W Washer - Top Loading
Amana LW8413L2 Washer - Top Loading
Amana LW8413W2 Washer - Top Loading
Amana LW8413W2B Washer - Top Loading
Amana LW8463L2 Washer - Top Loading
Amana LW8463W2 Washer - Top Loading
Amana LW9003 Washer - Top Loading
Amana LW9103 Washer - Top Loading
Amana LW9103W Washer - Top Loading
Amana LW9203L2 Washer - Top Loading
Amana LW9203W Washer - Top Loading
Amana LW9203W2 Washer - Top Loading
Amana LWA05AW Washer - Top Loading
Amana LWA10AW Washer - Top Loading
Amana LWA18AW Washer - Top Loading
Amana LWA20AW Washer - Top Loading
Amana LWA30AL Washer - Top Loading
Amana LWA30AW Washer - Top Loading
Amana LWA30BL Washer - Top Loading
Amana LWA30BW Washer - Top Loading
Amana LWA40AL Washer - Top Loading
Amana LWA40AL2 Washer - Top Loading
Amana LWA40AW Washer - Top Loading
Amana LWA40AW2 Washer - Top Loading
Whirlpool LWA4800W1
Amana LWA50AL Washer - Top Loading
Amana LWA50AW Washer - Top Loading
Whirlpool LWA5300W0
Whirlpool LWA5300W1
Whirlpool LWA5300W2
Whirlpool LWA5300W3
Whirlpool LWA5304W0
Whirlpool LWA5304W1
Whirlpool LWA5304W2
Whirlpool LWA5304W3
Whirlpool LWA5305W0
Whirlpool LWA5305W1
Whirlpool LWA5305W2
Whirlpool LWA5305W3
Whirlpool LWA5309W0
Whirlpool LWA5309W1
Whirlpool LWA5309W2
Whirlpool LWA5309W3
Whirlpool LWA5500W0
Whirlpool LWA5500W1
Whirlpool LWA5505W0
  #2 (permalink)
Old 09-19-2007, 08:52 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi ironglen
The motor has the overload protection and if the motor stopped it does not mean it's gone. The original belt suppose to be 32 1/2" and if the belt you installed is shorter it put more tension on the motor and overload it.
Remove the belt and start the washer without the belt. If the motor works fine then I would recommend to replace the belt only and there is a great chance the washer will work.
- The part number for the new belt AP74961
- Here are the break down diagrams for the Amana washer Model LW8203L2
Good luck.
__________________
  #3 (permalink)
Old 09-20-2007, 08:28 AM
Junior Member
Default
Gene,
Tried your idea and it worked! Will replace belt with correct length.
Thanks for the knowledgeable help AND the extremely fast response.
Glen
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer vibrates in spin when empty allan3367 Washer Repair 7 01-30-2010 06:23 AM
Roper washer wont spin and wont empty jgirl14572 Washer Repair 2 10-11-2009 06:54 AM
Maytag Washer doesn't empty all water during spin jdardiff62 Washer Repair 1 01-20-2009 10:05 AM
Washer not draining / spin when loaded but will when empty tay21105 Washer Repair 0 09-07-2008 10:51 AM
Washer will fill and wash, but not spin and empty cwp Washer Repair 0 11-06-2007 09:22 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
