Discuss
How to Replace Bad Bearing/Leaky tub
 in
Washer Repair
I have a stackable Fridgidaire washer/dryer thats making a lot of noise (grinding/whining noise) when in spin cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How to Replace Bad Bearing/Leaky tub
  #1 (permalink)
Old 09-19-2007, 06:00 PM
Geor2c Geor2c is offline
Junior Member
Geor2c is on a distinguished road
Default How to Replace Bad Bearing/Leaky tub
Model Number: flse72gcs4   Brand: Frigidaire   Age: 5 - 10 years
I have a stackable Fridgidaire washer/dryer thats making a lot of noise (grinding/whining noise) when in spin cycle and has a small drip leak - it appears to also be spatting a bit of oil of some sort?
What parts do I need and how to tackle repair?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-19-2007, 06:42 PM
Matt / APP Team Matt / APP Team is offline
Administrator
APP Team
Matt / APP Team is on a distinguished road
Default
Click for parts breakdown.
If you are leaking oil and water you may need a tub seal and a tranny. This is a pretty big job we wont have any step by step directions but I can provide you with the parts information.
Click for outer tub bearing.
Click for water seal.
Click for transmission.
If you feel like you want to repair the tranny, some parts are available if you can determine where the oil is.
Tranny breakdown.
__________________
Those who don't learn from history are doomed to relive it!
  #3 (permalink)
Old 09-21-2007, 04:02 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull the belt off the tranny and turn tranny pulley both ways, if it feels rough in spin direction, you have a bad tranny. Look above tranny for water marks. If present, you have bad tub bearings/seals. Click on your model # for parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaky Motor Seal boscoe Dishwasher Repair 2 08-24-2007 12:24 PM
how do I: remove rear drum bearing frigid front load? treefrog Washer Repair 0 08-19-2007 02:12 PM
How to Replace top agitator? JasonS Washer Repair 2 08-18-2007 08:56 AM
Rear Tub Bearing Justncase Washer Repair 5 08-08-2007 10:54 PM
Removing rear bearing above brake assembly Scott Washer Repair 2 08-04-2007 10:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
