I have a Frigidaire front load washing machine. There is a noise that sounds like it is coming from between the barrels. It does not sound metallic Is there a way for things to get in there? and do you have to completely take everything apart to check?
I printed the diagram. What are the vanes you are talking about?
Is there a repair manual available?
Originally Posted by: Cummingsen I printed the diagram. What are the vanes you are talking about? The vanes are shown as #17 on the diagram. The repair manual is not available on line for this washer. Gene.
Hello.
I have the same exact problem. Sounds like something is bouncing around inside the drum somewhere. I'd imagine it be a bit hard for something to get in there.
Anyway, it started to get louder over time until I had to take it apart today. Turns out the bearings are shot and broken into pieces!
So you may have the same problem. Have fun, because to get anything out between the drums or to fix the bearings, you have to tear that drum out of the machine. It's a learning experience, but I was able to do it so you should not have much problem.
If you are going to do this yourself, I suggest you buy the Service Manual. I found one online for about $10. It gives you piece of mind and it told me to do a few things I would not have thought of, like laying the machine on its back when you release the springs to leave the drum on the floor.
