Discuss
Spin Cycle/Bearing sound
 in
Washer Repair
My Neptune washer/dryer has had survice in the past, warrenty on motor and rubber lining. Now I have a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spin Cycle/Bearing sound
  #1 (permalink)
Old 09-07-2008, 07:37 PM
jmoore56 jmoore56 is offline
Junior Member
jmoore56 is on a distinguished road
Exclamation Spin Cycle/Bearing sound
Model Number: MLE2000AYW   Brand: Maytag   Age: 5 - 10 years
My Neptune washer/dryer has had survice in the past, warrenty on motor and rubber lining. Now I have a very loud spin cycle. I think it is bearing noise. I have looked at the part diagram and see a support, part # ap4324795 but no bearing unless they are here. As a front loader it does not have bearings in the front and back of the drum.
I saw something about a tub and basket repacement here on the forum when if cames to front loaders.
Any help is apprecieated.
Jim
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-08-2008, 03:35 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you remove the belt from the spin basket pulley in the back of the washer, you should be able to feel the bad bearings by turning the pulley.
If bad, try to get it fixed soon as the increased load on the motor and drive electronics will eventually burn them out.
Go to my article in the Forum announcements section (replacing Neptune bearings). This is a rather involved repair, expensive if done by a pro.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag neptune bad spin bearing check richappy General Talk 2 04-26-2008 08:58 AM
Agitator makes loud "smashing sound" during spin cycle Spug Washer Repair 3 04-06-2008 06:43 PM
loud whirring sound during spin cycle cbc123 Washer Repair 0 04-05-2008 01:05 PM
spin bearing very noisy davthorne Washer Repair 4 03-28-2008 12:07 AM
Buzzer sound during drain cycle zmgraham Washer Repair 1 02-24-2008 12:39 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
