| » Kenmore laundry center |
Model Number: 417.99812990 Brand: Kenmore Age: 1 - 5 years
Hello All!
![]() I have a Kenmore laundry center. I recently had the dryer motor replaced (which I probably could have done myself if I knew that was the problem) and $400 later was bummed when a month later my washer no longer agitates nor spin. I am not an expert but am mechanically inclined. I am the daughter of a mechanic! I do not want to get ripped off on this repair. ![]() I removed the front panel to inspect the belt and it is fine. The tub does fill up with water but does not spin nor agitate. Any suggestions! Please help a girl who is tired of being taken advantage of! ![]() |
The first thing I would check is the lid switch/lock assembly.
__________________
Professional appliance repair in Los Angeles, California. |
Remove the access panel (under the dryer) and look for the wiring diagram.
According to this diagram and the picture of the part (bellow) the lid/lock switch assembly consists of two switches. The lid switch provides neutral for all parts of the washer except the motor while the second circuit for the motor goes through the lock. This is the failure suspect. - The part number for the lid switch/lock assembly is AP2108159 Gene.
__________________
| Display Modes | |
| oil in center post?? | wedrons | Washer Repair | 2 | 07-16-2008 07:32 PM |
| Ice not solid in the center | turnkey | Refrigerator & Freezer Repair | 0 | 04-16-2008 10:38 AM |
| wash tub off center | daveperk | Washer Repair | 1 | 01-24-2008 12:21 PM |
| kenmore laundry center thermal limiter | sunshine5500 | Dryer Repair | 1 | 01-16-2008 01:10 PM |
| Kenmore Laundry Center - Washer Clutch Question... | ascdesigns | Washer Repair | 1 | 01-02-2008 11:21 AM |
