Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Direct Drive Washer (http://forum.appliancepartspros.com/washer-repair/1168-direct-drive-washer.html)
JNOLES 09-19-2007 09:41 AM
Direct Drive Washer
The washer is not spinning but it is agitating. I checked the coupler and it spins fine. I turned the washer on with the side cover and the center plastic cover that goes over the shaft removed and you can see the clutch spin but the shaft is not moving. Any idea as to what it may be.
Matt / APP Team 09-19-2007 05:24 PM
Here is the parts breakdown: Parts list
I would suspect the lid switch or the lid switch strike.
Click here: Lid switch
Click here: Lid switch bumper
You can test the lid switch for continuity and I believe the lid hinge activates the switch so look and make sure the bumper didnt fall off.
