Washer goes up to the rinse cycle, fills the washer with water but will not aggitate. All other cycles work
Since all of the mechanics work I think the problem is with the control assembly, this part here. Part number: AP3140343
It is an expensive part, but if you order it from this site and it does not fix things you can return it for a refund. See the returns policy or check with the customer rep when you order.
