Discuss
kenmore he2t F-20 error
 in
Washer Repair
I have recently read this thread, but it didn't work for me. Is there anything else I can try. thanks
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore he2t F-20 error
  #1 (permalink)
Old 08-20-2010, 09:04 AM
Junior Member
Bluesfanjte69 is on a distinguished road
Default kenmore he2t F-20 error
Brand: Kenmore   Age: 1 - 5 years
Problem:
F20 code - F20 code appears aprox 6-7 minutes after I start the cycle. I noticed this as I have spent the last two hours watching the cycles and taking it apart. The tub is also overfilling - which explains the 6-7 minutes and the F20.
This is what I have checked:
1. No siphoning issue. Drain goes into laundry tub (no stand-off). Laundry tub and drain pipe lengths are at proper heights and lengths.
2. Drain Pump opened up and checked pump impeller - I did find some coins and a screw in the drain pump - But did not fix problem.
3. Pressure switch. I blew into the pressure hose. But still having same problem.
Read more: Kenmore HE2T Error F20 with tub overfill problem is pressure switch
http://forum.appliancepartspros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HE2t front load washer wont spin khtarr Washer Repair 2 01-31-2016 11:42 AM
Kenmore HE2t F-28 code caitlinkf Washer Repair 3 01-06-2010 06:32 AM
how to Replace front loader door gasket Kenmore HE2t motopopsx5@msn.com Washer Repair 1 11-12-2009 07:15 PM
Kenmore Front Load washer HE2t marlenel Washer Repair 1 07-26-2009 07:11 AM
Kenmore HE2T Error F20 with tub overfill problem is pressure switch jaj_wis Washer Repair 0 02-04-2009 12:31 PM
