How do you replace lid switch?
Originally Posted by: ypauly How do you replace lid switch? Here is an excerpt from a previous response for the same information you are requesting. Good Luck, :) :) :)
1. Loosen the two screws in the console and flip the console up on its hinges 2. Remove the two brass clips in each corner 3. Disconnect the lid switch wire harness 4. Open the lid and tilt the cabinet toward you while lifting at the same time.
Now you should be able to change the switch out. When reassembling, make sure to line the four tabs on the base assembly with the four slots on the bottom of the cabinet.
Read more: http://forum.appliancepartspros...witch.html#ixzz0x4xFQGIm http://forum.appliancepartspros.com
