I'm lookin for any insight on where to start looking for leaks on this Amana washing machine. Never had to take apart any washer and could use a breakdown as to how I remove the topside and can access the drum and inner workings. Not sure if its leaking from lines going in or at pump for draining the unit.
If you will take out the two screws at the bottom of the front panel, the front panel should swing out and then come off.
You can now observe the machine while it runs and you should be able to determine where the leak is coming from.
