I have a whrilpool thin twin washer/dryer combo. The washer is working great (heat and spin) however the washer will not do anything at all no water fill at any setting. There was no problem with the unit until i had to disconnect the 30 amp double fuse to run another item. After reconnecting the fuse with the wire to the unit the washer will not work.
