| » Washer |
Quote:
First thing is to shut the power off or unplug the line cord to the machine. Remove the lower access panel of the dryer, (2 screws,1 screw on each corner of top of panel. Remove the 4 screws(2 on each side of the control panel, coverred by the lower access panel). Pull down and out on the bottom of the control console and un hook from the cabinet panel. Now for the hard part. On the back of the washer timer, where the timer shaft opening is located you will need to use a small, thin, screw driver or needle nose pliers, inside that "D" shaft opening you will see a retainer clip, you need to pry that clip out with the screwdriver or pull out with the needle nose pliers, and pull out on the timer knob, to remove the knob, then the skirt just slips off the remaining shaft housing. You'll find a single screw beside the timer shaft housing,remove that screw and lift up on the locking tab on the backside of the timer/control console and slide the timer to the right to release the remaining tabs. Remove the harness from the original timer, install it on the new timer and reverse procedure to install timer, control console, and panel. re establish power to the unit and test. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Washer/Dryer Stacked Unit - Washer won't start! | dru | Washer Repair | 4 | 09-21-2012 02:44 PM |
| help how do you speciffically replace washer timer on Maytag washer | stupid1 | Washer Repair | 5 | 07-04-2009 05:21 PM |
| is this model number washer a direct drive washer | dandjwashington | Washer Repair | 2 | 05-01-2009 07:26 PM |
| Change Washer Lid Switch on Stacked Washer/Dryer | scottcomputers | Washer Repair | 1 | 05-01-2009 10:16 AM |
| maytag washer/dyer combo washer no water | lindavanzandt | Washer Repair | 0 | 11-30-2008 08:35 AM |
