I can smell rubber during the spin and rinse cycle. The water won't drain from the mchine. I have checked the belt and it looks fine.
Check your pump for an obstruction or the pump may be out.
Has it been getting noisy durring the spin cycle?
Before it was broken, the washing machines became very noisy. Now it won't drain water after washing. After the machine is turned off for a long time and turned on again, it might start to drain. There is a big noise "zzzzzzzzz" before it starts working and might small rubber burning. Could you please tell me what's wrong with the machine? Thanks! Originally Posted by: ApplianceJunk Hi,
