| » GE Washer will not run cold |
Model Number: WVSR1060B3WW Brand: GE Age: 1 - 5 years
I have a GE washer that stopped allowing any cold water in. I had a water outage about a month ago and know there was sediment when the water was turned back on initially. It will run in hot or warm mode but not cold and will not operate in cycles where it expects cold water. When it gets to the rinse cycle for example, it just stops. I pulled off the hoses and cleaned the little strainer inside the inlet. Is there some way to flush the rest of the system to rerlease any sediment that got through the fine strainer or could it have burned something up? There water outage was about 7 weeks ago so this came out of the blue.
Here is a link to the parts list for the controls and backsplash... http://genet.geappliances.com/IPCNet...015864.p01.pdf Any help would be greatly appreciated. Tim Ads By Google Related Models Last edited by Timgod : 08-28-2008 at 04:16 PM. Reason: pdf was not showing up |
Check if there is 120VAC to the cold water solenoid on the water inlet valve (#805 on the break down diagram). Check this solenoid for continuity.
Post the results. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| kenmore washer no cold water | jasonkeg | Washer Repair | 4 | 06-16-2011 07:20 PM |
| ge WASHER, Cold/Cold does not work | no1zson | Washer Repair | 5 | 01-06-2010 07:06 PM |
| Washer won't fill with cold | Jllstarr | Washer Repair | 1 | 08-20-2009 05:14 PM |
| On my washer cold/cold is not working but others are?? | tinyaann | Washer Repair | 2 | 06-25-2009 05:33 PM |
| washer won"t run on cold cold water setting | jwh4969 | Washer Repair | 1 | 12-23-2008 06:41 AM |
